SGT4431 Posted August 29, 2007 Report Share Posted August 29, 2007 I would like to put my new center wheel caps on. How is the best way to jack up my SGT? Link to comment Share on other sites More sharing options...
SGT ShuttleGuy Posted August 29, 2007 Report Share Posted August 29, 2007 Had the same question when I wanted to change the oil. I got some rhino ramps ($34 for a pair) and built a couple of pre-ramps out of some 1x12's with 2x12's (scrap wood from Home Depot) on top to ride up on just in front of the rhino ramps(you'll still hit the rhino's without them). Link to comment Share on other sites More sharing options...
stump_breaker Posted August 29, 2007 Report Share Posted August 29, 2007 I kind of do the same thing except I just lay 2-2x4's cut about 3' long lengthwise in front of the ramp. I then use the same 2x4's as pressure equalizers between the floor jack and the jack point of the car. It works well. Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted August 29, 2007 Report Share Posted August 29, 2007 I just put a clean rag on the jack and it worked great. Dave C recommended I wax the inside of my wheels to prevent the brake dust from sticking. Thanks pal, it worked great. Link to comment Share on other sites More sharing options...
Crucible Posted August 29, 2007 Report Share Posted August 29, 2007 If you're talking about the Shelby GT wheel caps, just pop off the Mustang ones and snap on the new ones. No jacking needed. Link to comment Share on other sites More sharing options...
pottydr_merged Posted August 29, 2007 Report Share Posted August 29, 2007 If you are just changing the pony caps on the rims, I do not think you have to jack the car up, Just popped the old ones off and snapped in the new ones, damm too late Link to comment Share on other sites More sharing options...
zdle Posted August 29, 2007 Report Share Posted August 29, 2007 If you are just changing the pony caps on the rims, I do not think you have to jack the car up, Just popped the old ones off and snapped in the new ones, damm too late Makes sense to me...................................Why jack it to change a Cap? But if you want the car up to change oil get Race Ramps , they are twice as long , and have a low low incline angle , light weight , very easy to handle , and they don't scrape the front facia at all ZDS Link to comment Share on other sites More sharing options...
riharely Posted August 29, 2007 Report Share Posted August 29, 2007 Yes. I changed my caps a few weeks back. No jacking of car necessary at all. Get a small flat screwdriver and CAREFULLY pry off the exsisiting cap. I used a rag on the screwdriver so it wouldn't scratch the wheel. Once the old cap is off , pop the new one on with a easy hit of the palm of your hand. That is how it worked for me. -Tim- Link to comment Share on other sites More sharing options...
ShelbyCobra826 Posted August 29, 2007 Report Share Posted August 29, 2007 Yes. I changed my caps a few weeks back. No jacking of car necessary at all. Get a small flat screwdriver and CAREFULLY pry off the exsisiting cap. I used a rag on the screwdriver so it wouldn't scratch the wheel. Once the old cap is off , pop the new one on with a easy hit of the palm of your hand. That is how it worked for me. -Tim- I think that this issue is: do you go slowly and very carefully with the wheels on or take them off and simply knock the centers out from the back? Six of one, half dozen of the other, so long as you have a good floor jack and stands. Link to comment Share on other sites More sharing options...
shelbydream1 Posted August 29, 2007 Report Share Posted August 29, 2007 Those of you who've changed caps-what did you change to-got any pics?? Link to comment Share on other sites More sharing options...
zdle Posted August 29, 2007 Report Share Posted August 29, 2007 I think that this issue is: do you go slowly and very carefully with the wheels on or take them off and simply knock the centers out from the back? Six of one, half dozen of the other, so long as you have a good floor jack and stands. Please Please ............................It is not necessarey to jack the car to remove and replace the center cap, just use a thin common screw drive pop off the old ones , and install the new ones with the palm of your hand . REMEMBER Every time you jack a car up you take a chance of damaging it ! , Why would you jack a car if you dont have . Also don't jack this car if you are not removing a wheel ,,,,,,,,,,,,,,,,,,Use ramps , as I said before RCERAMPS makes a great product with a low long angled ramp , it won't scrap the facia................ZDS Link to comment Share on other sites More sharing options...
SGT2666 Posted August 29, 2007 Report Share Posted August 29, 2007 Please Please ............................It is not necessarey to jack the car to remove and replace the center cap, just use a thin common screw drive pop off the old ones , and install the new ones with the palm of your hand . REMEMBER Every time you jack a car up you take a chance of damaging it ! , Why would you jack a car if you dont have . Also don't jack this car if you are not removing a wheel ,,,,,,,,,,,,,,,,,,Use ramps , as I said before RCERAMPS makes a great product with a low long angled ramp , it won't scrap the facia................ZDS Google never heard of RCERAMPS ? Link to comment Share on other sites More sharing options...
mywickedshelby Posted August 29, 2007 Report Share Posted August 29, 2007 try "race ramps"....I just found ut thru Google Please Please ............................It is not necessarey to jack the car to remove and replace the center cap, just use a thin common screw drive pop off the old ones , and install the new ones with the palm of your hand . REMEMBER Every time you jack a car up you take a chance of damaging it ! , Why would you jack a car if you dont have . Also don't jack this car if you are not removing a wheel ,,,,,,,,,,,,,,,,,,Use ramps , as I said before RCERAMPS makes a great product with a low long angled ramp , it won't scrap the facia................ZDS ZDS, ARE THE 56'' ONES ON THE "RACE RAMP" SITE THE ONES THAT YOU BOUGHT FOR THE SGT? Link to comment Share on other sites More sharing options...
zdle Posted August 29, 2007 Report Share Posted August 29, 2007 try "race ramps"....I just found ut thru Google ZDS, ARE THE 56'' ONES ON THE "RACE RAMP" SITE THE ONES THAT YOU BOUGHT FOR THE SGT? The ramps are 67" , really good quality ,and easy to handle , I just store them vertically. http://www.raceramps.com/store/shopexd.asp?id=62&bc=no go to the site above, takes you right here. Google never heard of RCERAMPS ? Thats cause it should be RACE RAMPS , sorry bout that , check my last post....................ZDS Link to comment Share on other sites More sharing options...
shelby69 Posted August 29, 2007 Report Share Posted August 29, 2007 try "race ramps"....I just found ut thru Google ZDS, ARE THE 56'' ONES ON THE "RACE RAMP" SITE THE ONES THAT YOU BOUGHT FOR THE SGT? I bought the 56" race ramps and they worked fine with standard SGT wheels, front facia, etc... Also, get the 15% discount by entering cfcoup1. A Corvette club had this one and there are others. Makes them a little more affordable. Take care. Link to comment Share on other sites More sharing options...
SGT ShuttleGuy Posted August 30, 2007 Report Share Posted August 30, 2007 $299 minus 15% is still a little hard to swallow. I still like my cheapo rhino ramps and 2 by combo's. I can save the money to buy something for the car.....like new center caps! Link to comment Share on other sites More sharing options...
CrazyDave_merged Posted August 30, 2007 Report Share Posted August 30, 2007 I am kind of miffed :o . We should have gotten the Shelby wheel caps as standard equipment. This is a rip off in my opinion. Or, they should be about $20, not $109.99. Geeeezzzzz. And the rear faux gas cap should have come with Sheby GT (or Cobra) on it too. Anybody at SAI listening?????? Link to comment Share on other sites More sharing options...
shelby69 Posted August 30, 2007 Report Share Posted August 30, 2007 $299 minus 15% is still a little hard to swallow. I still like my cheapo rhino ramps and 2 by combo's. I can save the money to buy something for the car.....like new center caps! Actually, the 56" race ramps work fine. $199.00 minus 15% plus shipping. Expensive, yes, but they are well made in the USA. Link to comment Share on other sites More sharing options...
switch Posted August 31, 2007 Report Share Posted August 31, 2007 Are each of the Shelby center caps $110? Way too much. That should be the price for 4. Link to comment Share on other sites More sharing options...
CrazyDave_merged Posted August 31, 2007 Report Share Posted August 31, 2007 Are each of the Shelby center caps $110? Way too much. That should be the price for 4. You get a set of 4 for 110. Still way too much for little metal caps that should have come as standard Shelby upgrade. We paid $7300 to Shelby for about $3000 worth of Ford Racing parts. Pretty high labor in my opinion. But we get "the name" too. Guess that was worth something? No sure how much. Link to comment Share on other sites More sharing options...
AFBLUE Posted August 31, 2007 Report Share Posted August 31, 2007 We paid $7300 to Shelby for about $3000 worth of Ford Racing parts. Pretty high labor in my opinion. But we get "the name" too. Guess that was worth something? No sure how much. Well, it's worth $4300 to everyone that bought a SGT :D FWIW, I did a cost-benfit-analysis back in April on the SGT. http://forums.bradbarnett.net/showpost.php...040&postcount=1 I figured parts and labor at $4167 retail, so SGT owners are paying $3223 over that (excluding $1000 GGT) Link to comment Share on other sites More sharing options...
CrazyDave_merged Posted August 31, 2007 Report Share Posted August 31, 2007 I figured parts and labor at $4167 retail, I followed your link, very interesting. 3K for the name. Cheap I guess? Link to comment Share on other sites More sharing options...
