clawsonbob Posted July 8, 2007 Report Share Posted July 8, 2007 any expierence with the ford racing/whipple units ? if so, any hood clearence issues ? I gather std sgt strut brace won't work....any other braces that would fit over the FR Sc ( gt500, rousch etc) ? any insight appreciated also, what the performance level & expierence ? thanks bob Link to comment Share on other sites More sharing options...
stump_breaker Posted July 9, 2007 Report Share Posted July 9, 2007 any expierence with the ford racing/whipple units ? if so, any hood clearence issues ? I gather std sgt strut brace won't work....any other braces that would fit over the FR Sc ( gt500, rousch etc) ? any insight appreciated also, what the performance level & expierence ? thanks bob No experience yet but lot of research. I'm either going Whipple or Kenne Bell. Link to comment Share on other sites More sharing options...
goesfast Posted July 9, 2007 Report Share Posted July 9, 2007 The Ford Racing supercharger will fit nicely under the hood and add about 85HP to the motor, using the base model at approx. 5 PSI of boost. You can always opt for the higher horsepower model if you wish. The strut cross-brace will not fit with the supercharger in place but I understand that Ford is working on one that will. A nice way to boost overall HP, but expensive. Link to comment Share on other sites More sharing options...
RogerS Posted July 9, 2007 Report Share Posted July 9, 2007 Ford Racing superchargers are Whipple twin screw units. Get one the the air to water intercooler to maximize performance. Link to comment Share on other sites More sharing options...
stump_breaker Posted July 9, 2007 Report Share Posted July 9, 2007 I'm leaning toward the Kenne Bell system so I gave them a call. Here is the info. The 07 Mustang Kit (4.6 24V): Non-intercooled at 5 psi produces about 400 RWHP = $4599.00 (TS 1000-05) increase of 151 engine HP (RWHP/.85) Intercooled produces about 450 RWHP @ 8psi = $5699.00 (TS 1000-05-INT) ($1100 more for 50 HP??) Plus 140 s&h. They said not to boost a stock 4.6 more than 10psi or 480 HP and there should be no problems with hurting the engine. They also said it's not difficult to install but time consuming. http://www.kennebell.net/index.htm Link to comment Share on other sites More sharing options...
shelbygt350s Posted July 10, 2007 Report Share Posted July 10, 2007 I'm leaning toward the Kenne Bell system so I gave them a call. Here is the info. The 07 Mustang Kit (4.6 24V): Non-intercooled at 5 psi produces about 400 RWHP = $4599.00 (TS 1000-05) increase of 151 engine HP (RWHP/.85) Intercooled produces about 450 RWHP @ 8psi = $5699.00 (TS 1000-05-INT) ($1100 more for 50 HP??) Plus 140 s&h. They said not to boost a stock 4.6 more than 10psi or 480 HP and there should be no problems with hurting the engine. They also said it's not difficult to install but time consuming. http://www.kennebell.net/index.htm hi got a dumb question will the supercharger from the gt500 work on a 2005 mustang thanks Link to comment Share on other sites More sharing options...
stump_breaker Posted July 10, 2007 Report Share Posted July 10, 2007 hi got a dumb question will the supercharger from the gt500 work on a 2005 mustang thanks Two differrent engines. 5.4 vs. 4.6 so I seriously doubt it unless for some reason they have the same block. Link to comment Share on other sites More sharing options...
ShelbyPilot Posted July 10, 2007 Report Share Posted July 10, 2007 ....they certainly don't have the same block, did you mean manifold? Link to comment Share on other sites More sharing options...
GPStang06_merged Posted July 10, 2007 Report Share Posted July 10, 2007 any expierence with the ford racing/whipple units ? if so, any hood clearence issues ? I gather std sgt strut brace won't work....any other braces that would fit over the FR Sc ( gt500, rousch etc) ? any insight appreciated also, what the performance level & expierence ? thanks bob You shouldn't have any issues with any roots/twin screw designs with the stock hood as that is what most of them are fitted under. If you have or are planning on adding an aftermarket hood be prepared to make modifications to the inner layer (if the hood has one) as fiberglass hoods are generally thicker then the stock unit. I had to cut the center out on my CS6/GT-H hood to fit over my Roush blower. even with all that clear I have had the strut bolts hit now. Link to comment Share on other sites More sharing options...
Webba Posted July 10, 2007 Report Share Posted July 10, 2007 For those that dont have or arent going with the Paxton through SAI what is the reason? I am just curious to know. Link to comment Share on other sites More sharing options...
pottydr_merged Posted July 10, 2007 Report Share Posted July 10, 2007 I would have SAI Install a paxton, need to know 3 things, How much is the install, how long will it take and when can they install it. Link to comment Share on other sites More sharing options...
ShelbyPilot Posted July 10, 2007 Report Share Posted July 10, 2007 The Paxton install at SAI cost $6400 (parts and labor). I can't help you on the timeline. Also, if somebody really would prefer a roots type supercharger over the centirifcal Paxton, Shelbyperformanceparts.com has a roots type Ford supercharger on the site. I am sure the SAI mod shop can install that if you choose. Who knows it might even carry the Ford warranty. Somebody else will have to research that supercharger, I went with the Paxton installed by SAI. Link to comment Share on other sites More sharing options...
stump_breaker Posted July 10, 2007 Report Share Posted July 10, 2007 ....they certainly don't have the same block, did you mean manifold? No I meant block. Does the roots type blower not replace the intake manifold and bolt to the block? For those that dont have or arent going with the Paxton through SAI what is the reason? I am just curious to know. I would like to keep it all Shelby install but I'm not paying to have my car shipped to Vegas, sit for 6 months and then pay to have it shipped back. I also like the old school look of the roots type. (It's not a supercharger, it's a BLOWER!!) :D Link to comment Share on other sites More sharing options...
pottydr_merged Posted July 11, 2007 Report Share Posted July 11, 2007 How does one go about getting an appointment with SAI to do an install, thxs Link to comment Share on other sites More sharing options...
DreamRide Posted July 11, 2007 Report Share Posted July 11, 2007 How does one go about getting an appointment with SAI to do an install, thxs When i talked to Bud when i was there about the install's and such, he said at this time i might be better waiting till the end of or first of the year to have it done so be ready for a wait. The Paxton install at SAI cost $6400 (parts and labor). I can't help you on the timeline. Also, if somebody really would prefer a roots type supercharger over the centirifcal Paxton, Shelbyperformanceparts.com has a roots type Ford supercharger on the site. I am sure the SAI mod shop can install that if you choose. Who knows it might even carry the Ford warranty. Somebody else will have to research that supercharger, I went with the Paxton installed by SAI. It wont come with a warranty (Part maybe). I can get one thru the dealer across from mine for a good price but, no install and they say No warranty on my motor. Link to comment Share on other sites More sharing options...
pottydr_merged Posted July 11, 2007 Report Share Posted July 11, 2007 Is there anybody in Calif. that can do the authorized install ? Link to comment Share on other sites More sharing options...
ShelbyPilot Posted July 11, 2007 Report Share Posted July 11, 2007 Is there anybody in Calif. that can do the authorized install ? ...try Hillbank Motorsports, Irvine. Link to comment Share on other sites More sharing options...
Webba Posted July 11, 2007 Report Share Posted July 11, 2007 Thanks for the info guys! I guess I will have to do alot of research before I do this. I prefer the Paxton because it is SAI done and will keep it all Shelby but it sounds like there are many types of chargers and differences so who knows. If Tasca Ford ends up being a East Coast SAI installer it will make the decision ALOT easier. Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted July 11, 2007 Report Share Posted July 11, 2007 Thanks for the info guys! I guess I will have to do alot of research before I do this. I prefer the Paxton because it is SAI done and will keep it all Shelby but it sounds like there are many types of chargers and differences so who knows. If Tasca Ford ends up being a East Coast SAI installer it will make the decision ALOT easier. Webba, whether Tasca ends up being the East Coast installer or not, they can still install the Whipple. They offered to do it for me months ago. Link to comment Share on other sites More sharing options...
autoplay Posted July 11, 2007 Report Share Posted July 11, 2007 I'm in favor of the Kenne Bell model myself. Will probably go with Shelbys line as,I want the SC striping. Wondering if I scratch up the cash by the end of the year,if my wifey can be talked into it? Welcome help from you-all here,into talking her into the NEED of such Link to comment Share on other sites More sharing options...
mffarrell Posted July 11, 2007 Report Share Posted July 11, 2007 I'm in favor of the Kenne Bell model myself. Will probably go with Shelbys line as,I want the SC striping. Wondering if I scratch up the cash by the end of the year,if my wifey can be talked into it? Welcome help from you-all here,into talking her into the NEED of such Better save some extra $$$ for wifey's diamonds, then you will sure to get her buy-in for your S/C. B) Link to comment Share on other sites More sharing options...
pottydr_merged Posted July 11, 2007 Report Share Posted July 11, 2007 So if I have someone else installed the paxton, will SAI sell me the shelbyGT/SC decals? Link to comment Share on other sites More sharing options...
shelby69 Posted July 11, 2007 Report Share Posted July 11, 2007 So if I have someone else installed the paxton, will SAI sell me the shelbyGT/SC decals? SAI installed my Paxton and sent the GT/SC stickers later.... Link to comment Share on other sites More sharing options...
Webba Posted July 12, 2007 Report Share Posted July 12, 2007 You only get the GT/SC decals from SAI now if THEY do the install. We had a thread about this oh say about a month ago I am guessing. Link to comment Share on other sites More sharing options...
pottydr_merged Posted July 12, 2007 Report Share Posted July 12, 2007 I talked to SAI @ 4pm and they said they would ship them to Hillbanks and they could install them for me Link to comment Share on other sites More sharing options...
mffarrell Posted July 12, 2007 Report Share Posted July 12, 2007 I talked to SAI @ 4pm and they said they would ship them to Hillbanks and they could install them for me Will SAI also ship the SC stripe? Link to comment Share on other sites More sharing options...
pottydr_merged Posted July 12, 2007 Report Share Posted July 12, 2007 yes, they will ship them to the installer Link to comment Share on other sites More sharing options...
ShelbyPilot Posted July 12, 2007 Report Share Posted July 12, 2007 ....hmmmm, maybe to Hillbank Motorsports but even that might cause a stir. It was just a couple of months ago when Bud said they would not be sending "/SC" stripes out. That the supercharger had to be installed by Shelby. BUD????? Link to comment Share on other sites More sharing options...
stump_breaker Posted July 12, 2007 Report Share Posted July 12, 2007 Better save some extra $$$ for wifey's diamonds, then you will sure to get her buy-in for your S/C. B) It wont work. I bought my wife a 2 carat Diamond ring in Jan for our Anniversary and then the Shelby a few months later. I still can't get a blower...... Bribery gets you nowhere after they got papers on you. *sigh* <_< :rolleyes: Link to comment Share on other sites More sharing options...
ShelbyPilot Posted July 12, 2007 Report Share Posted July 12, 2007 .....LOL, stump I feel for you. I bought mine the tennis bracelet she has wanted since she was a little girl. It did work for me. Link to comment Share on other sites More sharing options...
