Webba Posted July 2, 2007 Report Share Posted July 2, 2007 My L came off the first week I got her. My son was opening the trunk and pushing up on the crease and his hand pushed the letter. I saw something fly onto the car and surprise it was the L. i just stuck it back on and it is staying on fine now. Link to comment Share on other sites More sharing options...
MattInDetroit Posted July 2, 2007 Report Share Posted July 2, 2007 My L came off the first week I got her. My son was opening the trunk and pushing up on the crease and his hand pushed the letter. I saw something fly onto the car and surprise it was the L. i just stuck it back on and it is staying on fine now. That sort of scares me as I can see a rag or sponge catching on the letter and it coming of. They did seem to stay on the GT-H cars and I consider these to be more manhandled by the typical renter and Hertz cleaning porter than our cars will ever be. Link to comment Share on other sites More sharing options...
Webba Posted July 2, 2007 Report Share Posted July 2, 2007 Sort of scares me is an understatement when I saw the letter fly onto my back window. Im sure my son was thinking "Im a dead man". LOL I have been careful when washing and polishing since then and havent had any issues. Link to comment Share on other sites More sharing options...
blueshawk Posted July 23, 2007 Report Share Posted July 23, 2007 Although not complete - I've just been veggie'ing out today after fighting a massive migrane last night - this will give you a peek at the started work. The back rivets have not been replaced yet and you can see the rivet that did not catch on the drivers side. Autoplay, you are correct. The hood is not forgiving but if you use the 1/2" rivets it will catch the underside steel of the hood as well. seriously though, if anyone else does this use no less than !/2" aluminum rivets and be careful of the tension you put on the scoop itself. It will cause a ripple effect if you pull it too tight. I still think that this idea would work but instead of rivets, use the same screws (button head sockets) SAI is now using for the front corners. That way you could adjust the tension and probably remove most of the ripple affect. A little ripple isn't bad 'cause it gives it the "fabricated" look. But it is very labor intensive. I'm anxious to know what SAI is coming up with? Link to comment Share on other sites More sharing options...
MadMax1228 Posted July 23, 2007 Report Share Posted July 23, 2007 I still think that this idea would work but instead of rivets, use the same screws (button head sockets) SAI is now using for the front corners. That way you could adjust the tension and probably remove most of the ripple affect. A little ripple isn't bad 'cause it gives it the "fabricated" look. But it is very labor intensive. I'm anxious to know what SAI is coming up with? I would be very dissapointed if I owned a car that had issues like this so soon after purchase. In my opinion,SAI should make this right.......maybe using the same type of shaker found on the '03 and '04 Mach 1 Link to comment Share on other sites More sharing options...
blueshawk Posted July 23, 2007 Report Share Posted July 23, 2007 I would be very dissapointed if I owned a car that had issues like this so soon after purchase. In my opinion,SAI should make this right.......maybe using the same type of shaker found on the '03 and '04 Mach 1 Actually I love the scoop! It is the best looking (IMO) scoop out there. I much rather have it than the CS6 hood or something else. It just needs to fit better and I'm sure SAI will do it. I'm just a mechanical engineer that likes to tinker with design ideas. Please bear with me. Link to comment Share on other sites More sharing options...
