Budman340 Posted April 14, 2007 Report Share Posted April 14, 2007 Hi all!!!!!! Oops, I forgot one. First you will need to remove the trim panels from the rear covering the mounting hardware for the tail lights. 2 plastic screw pins, 4 push pins must be removed as well. undo and then Remove the cover from the inside the trunk, there are 3 10MM bolts for each lamp as well. Slide the lamp out , unplug the stock wire harness. Remove the lamps from the tail lamp and switch bulbs onto new harness, try not to touch the bulb. Plug new harness into existing harness and reinstall harness back into the tail light assembly. Install the tail lamps back into the vehicle, replace all hardware. The lights are now ready for use. Bud ps. If you have ANY questions at all, please email me at Budm@shelbyautos.com I will be more than happy to help you out!!!!!! Link to comment Share on other sites More sharing options...
VEGASTY Posted April 15, 2007 Report Share Posted April 15, 2007 Hi all!!!!!! Oops, I forgot one. First you will need to remove the trim panels from the rear covering the mounting hardware for the tail lights. 2 plastic screw pins, 4 push pins must be removed as well. undo and then Remove the cover from the inside the trunk, there are 3 10MM bolts for each lamp as well. Slide the lamp out , unplug the stock wire harness. Remove the lamps from the tail lamp and switch bulbs onto new harness, try not to touch the bulb. Plug new harness into existing harness and reinstall harness back into the tail light assembly. Install the tail lamps back into the vehicle, replace all hardware. The lights are now ready for use. Bud ps. If you have ANY questions at all, please email me at Budm@shelbyautos.com I will be more than happy to help you out!!!!!! FYI from me the newbie may want to mention that the lamp slides out from the outside of car and to have towel to lay it on as you switch harnesses. Link to comment Share on other sites More sharing options...
SWEDESHELBY1 Posted April 15, 2007 Report Share Posted April 15, 2007 Thanks for the good information and proper installation techniques. I should have my order in by Tuesday I love the way they look. 2007 Shelby GT Black, 5 speed NAV and loving it! :D Link to comment Share on other sites More sharing options...
