HARALD KELLEY Posted May 14, 2019 Report Share Posted May 14, 2019 Is there a trick to removing the radiator cover on our GT-H/SGTs? I removed the 6 plastic push pins but the 2 hood pin rods are preventing the cover from lifting off, whats the trick or do I need to remove the grill Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 14, 2019 Author Report Share Posted May 14, 2019 Disregard, I got it, its fairly flexible and slightly bending it and using the plastic pin removal tool helps Quote Link to comment Share on other sites More sharing options...
BlackSGT Posted May 14, 2019 Report Share Posted May 14, 2019 Remove 6 pins. Push the cover towards the engine to release from the upper grille "grove", lift pull back and slide forward from under the hood pin plates. Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 14, 2019 Author Report Share Posted May 14, 2019 1 hour ago, BlackSGT said: Remove 6 pins. Push the cover towards the engine to release from the upper grille "grove", lift pull back and slide forward from under the hood pin plates. Thanks, I did get it off. I actually had to use a plastic pin removal tool and slide it between the grill the cover to get it to release from the grill and then pull it forward to get the opening area Shelby cut to clear the pin towers. Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 14, 2019 Author Report Share Posted May 14, 2019 Just noticed the header on this topic. Not sure how that happended. I cannot correct it. None the less, all done Quote Link to comment Share on other sites More sharing options...
Dan Espejo Posted May 14, 2019 Report Share Posted May 14, 2019 Is the radio leaking? Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted May 14, 2019 Report Share Posted May 14, 2019 10 hours ago, H0050 said: Just noticed the header on this topic. Not sure how that happended. I cannot correct it. None the less, all done Title fixed Glad you were successful with the cover removal.. Quote Link to comment Share on other sites More sharing options...
IASHELBYGT Posted May 14, 2019 Report Share Posted May 14, 2019 The cover on my GT-H was harder to remove than my 2007 SGT. I swear the hood pin cut outs on the cover were a little smaller on the GT-H, so I experienced what you did last winter when I swapped out my grille. Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted May 15, 2019 Report Share Posted May 15, 2019 20 hours ago, IASHELBYGT said: The cover on my GT-H was harder to remove than my 2007 SGT. I swear the hood pin cut outs on the cover were a little smaller on the GT-H, so I experienced what you did last winter when I swapped out my grille. Very well could be. SAI has a tool that "punches" out those slots and I suspect that tool came about with the increased production numbers for 2007-08 and was not around for the first builds in 2006. Steven Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 15, 2019 Author Report Share Posted May 15, 2019 Agree, the cut out are kinda crude on the 06 GT-Hs that made it a slight challenge. That said thanks Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 15, 2019 Author Report Share Posted May 15, 2019 20 hours ago, IASHELBYGT said: The cover on my GT-H was harder to remove than my 2007 SGT. I swear the hood pin cut outs on the cover were a little smaller on the GT-H, so I experienced what you did last winter when I swapped out my grille. Spot on Quote Link to comment Share on other sites More sharing options...
