EmpireStateGT500 Posted August 2, 2007 Author Report Share Posted August 2, 2007 Good luck on the 4th. She's a beauty and if I were a betting man I would bet you take a first place trophy home with you. Does the gas fill give you any problems in that location? Link to comment Share on other sites More sharing options...
67SuperSnake Posted August 2, 2007 Report Share Posted August 2, 2007 Good luck on the 4th. She's a beauty and if I were a betting man I would bet you take a first place trophy home with you. Does the gas fill give you any problems in that location? Thanks! The initial gas fill tube I purchased from UP was too tall on the tank end, causing a negative flow area. I had to cut it down a little. It does have a separate vent line. But the answer is yes. I have to fill it slowly. But no more so than the stock 67 mustangs. Even with the fill tube going to the rear panel, most of them have to be filled slowly. Link to comment Share on other sites More sharing options...
