Robert Bertich Posted September 19, 2018 Report Share Posted September 19, 2018 Purchased about a month ago. Only 32000 miles. Shifter seem a little stiff. Anyone know how to lube it? Quote Link to comment Share on other sites More sharing options...
BlackSGT Posted September 19, 2018 Report Share Posted September 19, 2018 The factory Hurst shifter in an SGT is "notchy", stiffer than a regular shifter. The only time mine got noticeably stiffer is when the throwback bearing was failing at 70K, and I had trouble slotting into gear. Hopefully, you're just not used to a tight Hurst shifter. Maybe someone else here can chime in about addressing lubrication, if needed. Quote Link to comment Share on other sites More sharing options...
Robert Bertich Posted September 25, 2018 Author Report Share Posted September 25, 2018 Thanks for the reply. I think you hit the nail on the head. Quote Link to comment Share on other sites More sharing options...
