mfield2a Posted March 21, 2018 Report Share Posted March 21, 2018 Finally had some time to bolt these up. This is the only “performance” mod on the car. 100% Stock Cold Start: Now with Atak: Quote Link to comment Share on other sites More sharing options...
Shelbygolfpro Posted March 21, 2018 Report Share Posted March 21, 2018 Sounds great! Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 6, 2019 Report Share Posted August 6, 2019 (edited) On 3/20/2018 at 11:02 PM, mfield2a said: Finally had some time to bolt these up. This is the only “performance” mod on the car. 100% Stock Cold Start: Now with Atak: Do you notice any resonance drone inside the cabin with the Borla ATAK's? I also have Borla ATAK's paired with Pypes exhaust cut n clamp X pipe to OEM cats and I notice drone in 5th gear only when the engine is under load between 1700-2000 RPM at 55-65 MPH when at cruise on the interstate. Once I'm at 70 MPH and at 2100 RPM and above, the drone goes completely away. Anyhow just curious if your running the stock catted mid-pipe with your Borla ATAK's or are you running either an off/road mid-pipe or long tube headers with high-flow cats? Thanks in advance. Edited August 6, 2019 by Supercharged "2006" GT Quote Link to comment Share on other sites More sharing options...
mfield2a Posted August 7, 2019 Author Report Share Posted August 7, 2019 6 hours ago, Supercharged "2006" GT said: Do you notice any resonance drone inside the cabin with the Borla ATAK's? I also have Borla ATAK's paired with Pypes exhaust cut n clamp X pipe to OEM cats and I notice drone in 5th gear only when the engine is under load between 1700-2000 RPM at 55-65 MPH when at cruise on the interstate. Once I'm at 70 MPH and at 2100 RPM and above, the drone goes completely away. Anyhow just curious if your running the stock catted mid-pipe with your Borla ATAK's or are you running either an off/road mid-pipe or long tube headers with high-flow cats? Thanks in advance. Interesting. I’m running a complete stock SGT set-up to the ATAKS and I get no drone, none at all. My car is a vert, but again nothing with the top up or down. A buddy of mine has ‘08 SGT/SC (vert) with a stock cats going into Bassani X into SLP loudmouths and the drone is unreal at 1700-2000 RPM. I thought it was the SLP’s, but maybe the X-Pipe is causing some of the baffle echo’s as well? Quote Link to comment Share on other sites More sharing options...
T-K Posted August 7, 2019 Report Share Posted August 7, 2019 I installed Borla Atak on my 2007 Super Snake a few years ago, sounded great, and no drone. Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 7, 2019 Report Share Posted August 7, 2019 13 hours ago, mfield2a said: Interesting. I’m running a complete stock SGT set-up to the ATAKS and I get no drone, none at all. My car is a vert, but again nothing with the top up or down. A buddy of mine has ‘08 SGT/SC (vert) with a stock cats going into Bassani X into SLP loudmouths and the drone is unreal at 1700-2000 RPM. I thought it was the SLP’s, but maybe the X-Pipe is causing some of the baffle echo’s as well? I really don't think it's the X pipe causing some of the baffle echos on your buddy's "08" SGT/SC (vert) Here's why. An X pipe is designed to push the amount of airflow out through the back of the exhaust more efficiently and faster than an H pipe which at least in theory is intended to minimize and produce the least amount of interior resonance drone. If on the other hand, your buddy was running an H pipe going into the SLP loudmouths? his drone would be far worse than it is with his Bassani X. Prior to running my current Borla ATAK's I actually considered getting SLP loudmouths until reading on several other Mustang forums about how horrible they drone even with the complete stock setup still in place. Also if I'm not mistaken, the stock exhaust setup for the "07-'08 SGT has the Ford Racing X crossover paired with the stock cats and Ford Racing GTA mufflers. So IMHO if it were the X -pipe causing some of the baffle echo's or causing any type of drone? you would also be experiencing drone on your SGT as well along with the Borla ATAKS. Therefore knowing that you don't get any drone at all with your complete stock setup to the ATAKS, we can pretty much rule out the Bassani X-Pipe as causing some of those baffle echo's on your buddy's '08 SGT/SC (vert) Anyhow before making the switch to the ATAKS, I was running Borla S-type (stingers) with both the Mac cut n clamp ProChamber to stock cats and also ran the ProChamber without cats as an off-road setup. Needless to say, it didn't matter which setup I ran, the drone was so unbearable that I couldn't wait to take off the Borla Stingers, S-Types soon enough lol. It's also possible the Mac ProChamber may also had been a contributing factor as well, but IMO most of the drone was caused by the Borla S-Type mufflers. At any rate, unless I'm 100% dead wrong about your complete stock SGT setup as having the FRPP X crossover? Then I also should not be getting any drone at all with running Borla ATAKS paired with the stock cats and X-Pipe 7 hours ago, T-K said: I installed Borla Atak on my 2007 Super Snake a few years ago, sounded great, and no drone. Did your Borla Atak mufflers have a round case housing or oval shaped? The reason for asking, is Borla made an Atak muffler for the 2007-09 Shelby GT500 as part of their cat-back exhaust system, part# 140480 which included oval shaped ATAK mufflers that have a different internal design over the round shaped ATAK 11806 muffler for the 2005-09 Mustang GT. So which ATAK mufflers do you have, the round shaped 11806 or oval shaped ATAK mufflers included with the 140480 cat-back system for the 2007-09 GT500? Here's an image and link for the ATAK mufflers included with the Borla 140480 cat-back exhaust for the 2007-09 Shelby GT500 https://www.americanmuscle.com/borla-atak-catback-0709gt500.html# Quote Link to comment Share on other sites More sharing options...
T-K Posted August 7, 2019 Report Share Posted August 7, 2019 I bought the ones for Mustang GT, round ones, like the KR exhaust. AM said that it would not fit GT500, but had no problems, had to tweek the hangers just a bit. Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 8, 2019 Report Share Posted August 8, 2019 (edited) Those idiots over at AM have no clue what they're talking about. The only reason Borla doesn't include listing the Mustang GT ATAK mufflers for the 2007-09 Shelby GT500, is Borla engineers their ATAK mufflers on a vehicle by vehicle basis with their patented straight-thru, multi-core design that is engineered around a vehicle's specific sound frequencies produced by the engine and it's exhaust components. Other than that, the Borla ATAK 11806 muffler engineered for the 2005-09 Mustang GT is fully compatible with the 2007-09 Shelby GT500 as the exhaust tubing has the same exact 2.5" size diameter and hanger mounting locations as the Mustang GT. Therefore they will fit on a GT500 with no problems, just as you said. The only real difference is their going to sound just a bit different when on a Shelby GT500. At any rate, now that you and Mfield2a have both confirmed there is no drone at all with running Borla ATAK mufflers? Then obviously I must be hearing something other than interior resonance drone Edited August 8, 2019 by Supercharged "2006" GT Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 8, 2019 Report Share Posted August 8, 2019 20 hours ago, T-K said: I bought the ones for Mustang GT, round ones, like the KR exhaust. AM said that it would not fit GT500, but had no problems, had to tweek the hangers just a bit. I forgot to ask how you go about tweeking the hangers. Are you referring to the tweaking the hanger brackets bolted onto the car's frame or the hanger rods attached to the mufflers? Quote Link to comment Share on other sites More sharing options...
mfield2a Posted August 8, 2019 Author Report Share Posted August 8, 2019 On 8/7/2019 at 4:30 PM, Supercharged "2006" GT said: Did your Borla Atak mufflers have a round case housing or oval shaped? The reason for asking, is Borla made an Atak muffler for the 2007-09 Shelby GT500 as part of their cat-back exhaust system, part# 140480 which included oval shaped ATAK mufflers that have a different internal design over the round shaped ATAK 11806 muffler for the 2005-09 Mustang GT. So which ATAK mufflers do you have, the round shaped 11806 or oval shaped ATAK mufflers included with the 140480 cat-back system for the 2007-09 GT500? Mine are the round type. I had to heat and bend the brackets on them a few times to get them to line up. The video I posted was prior to the adjustment and you can see they are slightly off. Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 9, 2019 Report Share Posted August 9, 2019 (edited) 3 hours ago, mfield2a said: Mine are the round type. I had to heat and bend the brackets on them a few times to get them to line up. The video I posted was prior to the adjustment and you can see they are slightly off. So you have the same round ones as I do which are the Borla ATAK part#11806. As for heating and bending the brackets, do you mean the brackets that are welded onto the mufflers or the actual OEM hangers attached to the frame? Edited August 9, 2019 by Supercharged "2006" GT Quote Link to comment Share on other sites More sharing options...
mfield2a Posted August 9, 2019 Author Report Share Posted August 9, 2019 1 hour ago, Supercharged "2006" GT said: So you have the same round ones as I do which are the Borla ATAK part#11806. As for heating and bending the brackets, do you mean the brackets that are welded onto the mufflers or the actual OEM hangers attached to the frame? I heated and bent the hangers attached to the mufflers. It was fairly simple with my set up as the driver side was just about dead on from the start. The passenger side took some work (as you can see in my clip, it was up and towards the center of the car), but I did the bends before tightening the clamps down to far, which made it easy to pull them off, bend, put back into place, check and repeat until I got them where I wanted. I think it only took me 3 cycles. Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 9, 2019 Report Share Posted August 9, 2019 15 minutes ago, mfield2a said: I heated and bent the hangers attached to the mufflers. It was fairly simple with my set up as the driver side was just about dead on from the start. The passenger side took some work (as you can see in my clip, it was up and towards the center of the car), but I did the bends before tightening the clamps down to far, which made it easy to pull them off, bend, put back into place, check and repeat until I got them where I wanted. I think it only took me 3 cycles. My driver's side is perfectly centered but is just barely a bit higher than the passenger side which is centered and perfectly level. Did you also consider adjusting the mufflers by loosening the over the axle pipes and then rotating them? I've heard that rotating them is also effective in adjusting the height and centering of the mufflers as well, but I've never really tried it, so I honestly can't say if that actually does anything for adjusting the mufflers or not? But it's something you just might find interesting never the less. Quote Link to comment Share on other sites More sharing options...
mfield2a Posted August 9, 2019 Author Report Share Posted August 9, 2019 (edited) 6 hours ago, Supercharged "2006" GT said: My driver's side is perfectly centered but is just barely a bit higher than the passenger side which is centered and perfectly level. Did you also consider adjusting the mufflers by loosening the over the axle pipes and then rotating them? I've heard that rotating them is also effective in adjusting the height and centering of the mufflers as well, but I've never really tried it, so I honestly can't say if that actually does anything for adjusting the mufflers or not? But it's something you just might find interesting never the less. I played with the rotation as well when centering. The issue I ran into quickly is the rotation changes the pitch and yaw, so I could get the tip centered but it was coming out on an angle. (If that makes sense). The only way I could get it centered and straight was bending the hanger. Also, I forgot to mention I bent the hangers at their original bend points only. Edited August 9, 2019 by mfield2a Quote Link to comment Share on other sites More sharing options...
T-K Posted August 9, 2019 Report Share Posted August 9, 2019 18 hours ago, Supercharged "2006" GT said: I forgot to ask how you go about tweeking the hangers. Are you referring to the tweaking the hanger brackets bolted onto the car's frame or the hanger rods attached to the mufflers? Hanger rods attached to the muffler Quote Link to comment Share on other sites More sharing options...
Supercharged "2006" GT Posted August 10, 2019 Report Share Posted August 10, 2019 15 hours ago, mfield2a said: I played with the rotation as well when centering. The issue I ran into quickly is the rotation changes the pitch and yaw, so I could get the tip centered but it was coming out on an angle. (If that makes sense). The only way I could get it centered and straight was bending the hanger. Also, I forgot to mention I bent the hangers at their original bend points only. I never knew that by rotating the OTA pipes would change the pitch of the mufflers? But yes, It does make perfect sense about what you mentioned concerning getting the tips centered, but were coming out on an angle, meaning that the tips weren't lining up straight like they're supposed to. Therefore I totally agree 100% and I thank you for providing such helpful and valuable feedback support 13 hours ago, T-K said: Hanger rods attached to the muffler That's what I thought, but wasn't 100% sure as some folks interpret muffler hangers as to the hanger brackets that are attached/bolted to the car lol. Quote Link to comment Share on other sites More sharing options...
