cobra 07 Posted September 28, 2017 Report Share Posted September 28, 2017 4956 mi on my 14 gt500 and only 6 trips down the 1/4 mi,over the last 2.5 yr.& not much high spirted driving-- Last sat. nite 1st trip down pulled like a freight train and did a 12,08 & 122 mph after missing 3rd gear. on the way back to pickup the time slip - no clutch - maybe blew the springs out????????????? anybody have that happen?? Thinking of a McLeod RXT 1000 - Is that a good choice?????????????? Quote Link to comment Share on other sites More sharing options...
ViperNC Posted September 28, 2017 Report Share Posted September 28, 2017 (edited) I was running the Shelby performance Twin Disc clutch and had nothing but problems. Don't get that one. RXT seems to be the most popular choice. Check your driveshaft as well to make sure it did not fail at the yoke. I believe you have a carbon shaft on your car. Mine recently failed and I had to get it warrantied. I thought it was only the clutch because I knew I was having problems with the clutch in the car at the time. After install of the RXT clutch the car still wasn't moving. Sure enough the carbon shaft broke at the aluminum yoke. All this happened at a track day after only 14 laps. Edited September 28, 2017 by ViperNC Quote Link to comment Share on other sites More sharing options...
cobra 07 Posted September 28, 2017 Author Report Share Posted September 28, 2017 Thanks for the infor I haven't even thought of the possibility of a driveshaft problem. I'll check it out before pulling out the clutch just in case. Quote Link to comment Share on other sites More sharing options...
