teuhl Posted July 24, 2017 Report Share Posted July 24, 2017 (edited) Recommendation for lug nut torque and tire pressure for 2017 Super Snake. Edited July 24, 2017 by teuhl Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 25, 2017 Report Share Posted July 25, 2017 tire pressure should be in door jamb probably 32-35 psi Lug nuts thinking 100 ft/lbs.... Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted July 25, 2017 Report Share Posted July 25, 2017 check your owners manual Quote Link to comment Share on other sites More sharing options...
Jimmy Sak Posted July 25, 2017 Report Share Posted July 25, 2017 Talk to SA Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted July 25, 2017 Report Share Posted July 25, 2017 Recommendation for lug nut torque and tire pressure for 2017 Super Snake. Thomas, I've asked Chris from our sales department to reach out to you with some answers. Because we change the wheel studs on the SS Chris is going to double check with Vince to see if the recommended torque has changed. Same with the tire pressure, because we change the wheels/tires Chris will also check on any air pressure changes. Steve Quote Link to comment Share on other sites More sharing options...
teuhl Posted July 31, 2017 Author Report Share Posted July 31, 2017 This is what I received from Austin Craig at Shelby American. Lug Torque - 140 ft/lbs Tire Pressure 40 to 45 lbs Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 31, 2017 Report Share Posted July 31, 2017 This is what I received from Austin Craig at Shelby American. Lug Torque - 140 ft/lbs Tire Pressure 40 to 45 lbs tire pressure should be in door jamb probably 32-35 psi Lug nuts thinking 100 ft/lbs.... Holy mother of pearl, glad you didn't listen to me... Quote Link to comment Share on other sites More sharing options...
teuhl Posted August 1, 2017 Author Report Share Posted August 1, 2017 (edited) I have just done a lot of research on tire pressure. The 40 to 45 psi seemed too high. I called Michelin and they calculated 37 psi max. and a low of 32 psi depending on your comfort preference based on the information from the door placard. Then I found this calculation on the internet that is below. The Total Wt. came from the door placard. The % is the Load Rating of the tire divided by the Per Wheel wt. The PSI was calculated based on the max. psi of 50 times the %. Bottom-line - Running the Michelins at 32 psi seems reasonable. Total Wt Per Wheel Size Load Rating % PSI Front End 2,325.0 1,162.5 275/35 1,874.0 62 31.0 Rear End 2,440.0 1,220.0 305/30 1,929.0 63 31.6 Edited August 1, 2017 by teuhl Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted August 1, 2017 Report Share Posted August 1, 2017 Just to clarify some things, only 2015-17 Super Snakes with SAI installed hardened wheel studs should be torqued to 150ft/lb And when it comes to tire pressure it all depends on what you are doing, meaning are you driving in town, on the race track, setting a LSR at the salt flats? For normal everyday driving SAI suggests 32-35psi. At the track 28psi is a good starting point. These are cold inflation numbers. Hope these SAI recommendations help. Quote Link to comment Share on other sites More sharing options...
Secondo Posted August 1, 2017 Report Share Posted August 1, 2017 Holy mother of pearl, glad you didn't listen to me... You lost us when you said "probably." Quote Link to comment Share on other sites More sharing options...
teuhl Posted August 1, 2017 Author Report Share Posted August 1, 2017 Just to clarify some things, only 2015-17 Super Snakes with SAI installed hardened wheel studs should be torqued to 150ft/lb And when it comes to tire pressure it all depends on what you are doing, meaning are you driving in town, on the race track, setting a LSR at the salt flats? For normal everyday driving SAI suggests 32-35psi. At the track 28psi is a good starting point. These are cold inflation numbers. Hope these SAI recommendations help. Quote Link to comment Share on other sites More sharing options...
teuhl Posted August 1, 2017 Author Report Share Posted August 1, 2017 Steven - This was very helpful and appreciated. Suggestion - It would be very helpful if information unique to the conversion of the stock Mustang to the Shelby SS be formally documented. This would include the above, alignment specs and any other information unique to the conversion. Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted August 2, 2017 Report Share Posted August 2, 2017 Steven - This was very helpful and appreciated. Suggestion - It would be very helpful if information unique to the conversion of the stock Mustang to the Shelby SS be formally documented. This would include the above, alignment specs and any other information unique to the conversion. While I certainly agree, something like that would be up to the sales director to put together. I'll pass on your suggestion to the team. Quote Link to comment Share on other sites More sharing options...
