PghFANATIC Posted May 9, 2017 Report Share Posted May 9, 2017 2010 Shelby GT500Can anyone confirm that an Air Release sound coming out of the Air Filter when the engine is turned off each time is NORMAL? Not heard while in the car with the hood down, but with Hood up and standing near the engine. It happens on every engine shut down.-- A POOF like sound escaping from the Air FilterAgain - My Local Ford Dealer Mechanic informed me that this is a normal occurrence with the Supercharger. And since I have an Aftermarket K&N Air Filter, it is even louder.Was told by another Senior Service ADVISOR - that K&N air filters are not very good and that they allow more dirt to enter the fuel system and destroys vehicles.Would like to know thoughts on K&N air filters and if this Air Poofing sound is in fact NORMAL.Thanks! Quote Link to comment Share on other sites More sharing options...
Secondo Posted May 9, 2017 Report Share Posted May 9, 2017 It happened on my GT500 sometimes and also the 5.0. It's normal to hear a slight "poof" but not an explosion sound. Quote Link to comment Share on other sites More sharing options...
PghFANATIC Posted May 10, 2017 Author Report Share Posted May 10, 2017 Well, this is every time the engine is shut down. Not noticeable from inside the car with the hood down.Just a Pssshhhhhh. sound - like an air brake being released. Definitely not an explosion thank god. Can you check your Shelby? Hood up and standing in front near engine. ( I guess if you lean out the Drivers window, you could hear it too) Quote Link to comment Share on other sites More sharing options...
The Chairman Posted May 26, 2017 Report Share Posted May 26, 2017 These cars have vacuum-powered brakes that store vacuum while the engine is running. That vacuum is developed right behind the throttle butterfly and before the supercharger. There is a check valve on the brake booster to hold that vacuum in case of power loss. But the line from the booster and the throttle body area has a vacuum in it. When the engine is shut off, the throttle blades close and that small amount of vacuum built up behind the blades vents into the intake tube, probably sounds like its coming out of the air filter. This is quite normal. As to K&N filters, that's all I have ever used, and have currently in all five of my vehicles. They work great and last essentially forever. Your service advisor wants to sell you a new air filter every time you stop in. Ignore them. Quote Link to comment Share on other sites More sharing options...
