weider1717 Posted May 2, 2017 Report Share Posted May 2, 2017 You have to take the CAI off (out of the car) along with the MAF sensor slide the rubber seal around the tube but I am having trouble on how to place the seal in regards to the "bracket" that has 3 holts for the 8mm bolts. I try to put the seal behind the bracket and doesn't seem right, you can't put it infront of the bracket because it won't slide up on the tube due to the tube flaring out wide so I slide the front of the "backed" under the seal which seemed to look how it goes but then you can't get the front 8mm bolt in due to the seal being in the way. I'm confused here surely the KR's frpp intake isn't any different anyone done this correctly please step in and help me Quote Link to comment Share on other sites More sharing options...
sheppd01 Posted May 2, 2017 Report Share Posted May 2, 2017 There is no bracket on the KR. The rubber seal is the bracket. Quote Link to comment Share on other sites More sharing options...
weider1717 Posted May 2, 2017 Author Report Share Posted May 2, 2017 ah makes sense now, haha Quote Link to comment Share on other sites More sharing options...
