Shelby95322 Posted April 21, 2017 Report Share Posted April 21, 2017 Hello, I'm really concerned about this issue, Sometimes when I try to start it, it just will not start, no clicking sounds, I replaced the battery, Installed Alternator High 200 Amp 2 years ago, I already went to three different Mechanical shops, Dealer and a Alarms place, They fixed the issue temporally but nothing permanent, they checked the starter, replaced relays, one of them told me, it had a aftermarket alarm and that was the problem, they took it off, it worked but next day the same issue. Right now the only way to make it start is to wait 1 or 2 hours and it will start like there is no problem, Or the last 3 times that it happened, I just disconnected the battery wait for 5 minutes, plug the battery again and will start. ECM?? This is my first post in this forum and I will really appreciate if someone can guide me in the right direction, Thank you. Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted April 21, 2017 Report Share Posted April 21, 2017 may be a bad starter, or starter experiencing thermal overload. Some people have replaced the starter and solved the issue. Good Luck and let us know if you get it solved. Quote Link to comment Share on other sites More sharing options...
Don Johnston Posted April 22, 2017 Report Share Posted April 22, 2017 Next time, immediately use a OBDII checker to see if any codes come up. Try to see if the car has accessory power before cranking. All the low voltage electronics and ECU can be a PIA to trouble shoot. Good luck. Let us know what the answer is once the problem is solved. Quote Link to comment Share on other sites More sharing options...
Shelby95322 Posted April 22, 2017 Author Report Share Posted April 22, 2017 Thank you all for your advice, I will keep you posted! Quote Link to comment Share on other sites More sharing options...
paul burgess Posted April 22, 2017 Report Share Posted April 22, 2017 my daughter had that a few years back,into ford five times,finally found falty starter would stop on bad spot replaced and no trouble Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted April 22, 2017 Report Share Posted April 22, 2017 Check the main battery to frame ground. Remove it and scrape any paint away from the frame under the ground cable end,clean the cable connector and reinastall. Quote Link to comment Share on other sites More sharing options...
Frank S Posted April 22, 2017 Report Share Posted April 22, 2017 No "click" leads me to the Ignition Switch? One time when it's dead, try jumping the starter motor with a screwdriver or remote switch. I had a General Motors car with that symptom, and a new ignition switch cured it. Quote Link to comment Share on other sites More sharing options...
