Bad Horse Posted April 16, 2017 Report Share Posted April 16, 2017 Any tricks on " burping" the intercooler system. No kinks in the lines and I have wired a switch to power the pump which is running .How long should it the take to primp the pump? Quote Link to comment Share on other sites More sharing options...
Bad Horse Posted April 16, 2017 Author Report Share Posted April 16, 2017 Any tricks on " burping" the intercooler system. No kinks in the lines and I have wired a switch to power the pump which is running .How long should it the take to primp the pump? Found the trick...squeeze the hose from the bottom of the tank to the pump about 10 times and it took right off. Quote Link to comment Share on other sites More sharing options...
barspen Posted April 16, 2017 Report Share Posted April 16, 2017 Yep, squeeze, with both hand if possible, on the bottom hose. If that doesn't do it, you can disconnect the lower hose, use a funnel to add new fluid into the top tank and let gravity push out the bubble. The second option will lose some fluid, but if its stubborn, might do the trick. Quote Link to comment Share on other sites More sharing options...
