dankeneipp Posted February 13, 2017 Report Share Posted February 13, 2017 I have 21,000 miles on my GT 500 and the transmission/clutch is slipping when I place more than light pressure on the gas. The RPM increases rapidly and then the car will begin acceleration. It is much worse when the vehicle is warmed up and at times, it feels like the car will not make it up a incline road. Has anyone else had these problems with the clutch's. I will be replacing pressure plate, clutch, slave cylinder/throwout bearing, pilot bearing and potentially the flywheel when the transmission is removed. Has anyone gone back to the OEM or used Summit Racing parts? ThanksDan Quote Link to comment Share on other sites More sharing options...
Cali_KR Posted February 13, 2017 Report Share Posted February 13, 2017 I have 21,000 miles on my GT 500 and the transmission/clutch is slipping when I place more than light pressure on the gas. The RPM increases rapidly and then the car will begin acceleration. It is much worse when the vehicle is warmed up and at times, it feels like the car will not make it up a incline road. Has anyone else had these problems with the clutch's. I will be replacing pressure plate, clutch, slave cylinder/throwout bearing, pilot bearing and potentially the flywheel when the transmission is removed. Has anyone gone back to the OEM or used Summit Racing parts? Thanks Dan Moderator: please move to correct GT500 sub-section. Ford OE is now on its 4th or 5th version, and I put v4 in my 08 KR, and absolutely love it. Peddle pressure is half of what it was. Quote Link to comment Share on other sites More sharing options...
Rarecat Posted February 13, 2017 Report Share Posted February 13, 2017 Search is your friend, many threads on clutches. I replaced mine with 17K on the clock Quote Link to comment Share on other sites More sharing options...
Bruce2009KR Posted February 13, 2017 Report Share Posted February 13, 2017 Mine went with same thing at about 22k miles. Pretty sad as it had not been abused. There's plenty of others crying the same blues. I went with the McLeod RXT after reading any nice reviews and it's butter smooth and she grips like a Tiger. Love it so far; only 500 miles or so on it. Quote Link to comment Share on other sites More sharing options...
Secondo Posted February 14, 2017 Report Share Posted February 14, 2017 (edited) OEM 4th revision has the most positive remarks here so far. My original clutch lasted about 35k miles and had Tasca Ford install the 4th revision setup; new clutch, flywheel, slave cylinder and lines. Smooth and held strong. Used it drag racing, track days, traffic, etc. without issue. Edit: About 8k miles without issue before I sold the car. See topics about it here: http://www.teamshelby.com/forums/index.php/forum/151-clutch-transmission/ Edited February 14, 2017 by Secondo Quote Link to comment Share on other sites More sharing options...
mach 1 1970 Posted February 15, 2017 Report Share Posted February 15, 2017 07 08 and some 09 GT 500's had flywheel problems from the factory. Search on this forum for advice. Quote Link to comment Share on other sites More sharing options...
grsybtch Posted February 16, 2017 Report Share Posted February 16, 2017 McLeod RXT put in at 22K........now at 85K on my daily driver.........Great clutch! Quote Link to comment Share on other sites More sharing options...
07gt500conv Posted February 16, 2017 Report Share Posted February 16, 2017 McCleod RXT on mine also, replaced at 28K, now have 76K on mine and NOT a daily driver, but still fun. Quote Link to comment Share on other sites More sharing options...
89Saleen215 Posted February 17, 2017 Report Share Posted February 17, 2017 I'm not sure what revision mine is, but it's the 2010 setup. Dealer did it @ 12,000 and now the car has multiple track days and just turned 81,000. No issues here. Quote Link to comment Share on other sites More sharing options...
kazman Posted March 27, 2017 Report Share Posted March 27, 2017 @ grysbtch ... Off topic, but you cannot receive any PMs, and I would like to find out the info on your wheels. What and where? If you would sir, please pm me the particulars. TIA, Dennis Quote Link to comment Share on other sites More sharing options...
sbrooks Posted June 21, 2017 Report Share Posted June 21, 2017 McLeod RST installed in mine a month ago. I had the same problems with my 2007. Quote Link to comment Share on other sites More sharing options...
