SHELB06 Posted November 29, 2016 Report Share Posted November 29, 2016 Does anyone have a closeup picture of a hood mounted windshield nozzle/jet for a 2006 Hertz? I specifically need side views of the area that's not visible, i.e. the area under the surface of the hood. Thanks in advance for any help. Craig R Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted November 29, 2016 Report Share Posted November 29, 2016 (edited) My hood is in storage otherwise I would take pictures. I switched to the Terlingua deep draw hood and I put on the relocation kit which puts the sprayers on the wiper arm. I think what you are asking is for the underside of the hood with the hood pad removed. I am sure someone here will help. If no luck in a few days, Ill pull mine out and try to get you a photo. Edited November 29, 2016 by H0050 Quote Link to comment Share on other sites More sharing options...
SHELB06 Posted November 29, 2016 Author Report Share Posted November 29, 2016 Thanks for the reply! When I purchased my car, one of the hood nozzles was missing. As you know these are unique to the Hertz specific hood and no longer supplied by SAI. No need to photograph yours as I can just remove the one I have from my hood. I was just hoping someone had a loose one that they could photograph. I'm trying to find one with a similar profile and dimensions. Didn't want to remove mine for fear of breaking it. Craig R. Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted November 29, 2016 Report Share Posted November 29, 2016 (edited) OK. Did a search and here is some discussion about a replacement that may work, its an older thread: http://www.teamshelby.com/forums/index.php/topic/58203-hertz-hood-windshield-washer-jetsnozzles/?hl=%2Bwasher+%2Bnozzles Edited November 29, 2016 by H0050 Quote Link to comment Share on other sites More sharing options...
SHELB06 Posted November 29, 2016 Author Report Share Posted November 29, 2016 ^^^ Thanks, I did see that post. I am trying to find a single nozzle that will just pop in there without any other modifications. It looks as if it has fore and aft tabs that pop into the hood. I will have to see if I can carefully remove the one I have to get more detail. There are lots of these out there for other makes/models of cars that look as if they will work. I'll keep researching. Thanks for the help. Craig R Quote Link to comment Share on other sites More sharing options...
ITHERTZ66 Posted November 30, 2016 Report Share Posted November 30, 2016 I bought a replacement set from SA a few years ago when they were still available. I have been less than satisfied with the fit. They do not properly grab and tighten down into the hood holes and keep "spinning" loose on their own. Perhaps what I was sent isn't truly an original part? Who knows... Quote Link to comment Share on other sites More sharing options...
SHELB06 Posted December 1, 2016 Author Report Share Posted December 1, 2016 I was very hopeful as SAI referred me to their original supplier, Classic Design Concepts. I contacted them and they stated that they carried them. I almost fell off my seat and ordered 2 @ $5.00 apiece. I knew it was too good to be true as they sent the ones that are part of the relocation kit. They mount on the wiper blades. The hunt continues. I will probably take a closer look at some of the ones used on other vehicles. Some appear to have the same push-in design that would work with the Hertz hood cutout. I can't remove the one I have completely as the tubing is attached. I'd like to see what the lower portion of the nozzle looks like. Can anyone help with a picture? Thanks! Craig R Quote Link to comment Share on other sites More sharing options...
okbobw Posted July 24, 2018 Report Share Posted July 24, 2018 I am also looking for the same jets for my new to me 06 GT-H. All that I have is the fluid bottle with pump, no hose or jets. Quote Link to comment Share on other sites More sharing options...
