harley99fb Posted July 6, 2007 Report Share Posted July 6, 2007 Finally got around to doing mine. Link to comment Share on other sites More sharing options...
BillyRay Posted July 6, 2007 Author Report Share Posted July 6, 2007 mine, after I fixed the screw up on the 'Y' THAT LOOKS REAL GOOD ON THAT BLACK AND SILVER!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
colt Posted July 6, 2007 Report Share Posted July 6, 2007 Cheaper still....Ebay! Got mine months ago for $29 shipped...and still in the Ford wrapper!! Do you have the saler name or contact? Link to comment Share on other sites More sharing options...
TexasShelby Posted July 6, 2007 Report Share Posted July 6, 2007 Actually I do. Call me a nerd, but I have a spreadsheet with every mod I've purchased with the info on each mod, as well as a wish list for things I'm looking into. Especially things members here have or have recommended. That way it's not so hard to have to go back and find a thread or a post again. the ebayer I got mine from is - bullitt03722 . Link to comment Share on other sites More sharing options...
svtkeith Posted July 6, 2007 Report Share Posted July 6, 2007 THAT LOOKS REAL GOOD ON THAT BLACK AND SILVER!!!!!!!!!!!!!!! Ray, Nice goat on your avatar, is it a 71 or 72?. Link to comment Share on other sites More sharing options...
chachi99 Posted July 7, 2007 Report Share Posted July 7, 2007 THAT LOOKS REAL GOOD ON THAT BLACK AND SILVER!!!!!!!!!!!!!!! thanks! i think so too. Link to comment Share on other sites More sharing options...
Super Snake Posted July 7, 2007 Report Share Posted July 7, 2007 A lot of us have changed the letters because we think it looks better. I'm not convinced that Ford put the lettering to the left because the 67 Shelby was that way. I still believe it was due to the strip source or outsource. Either way it is a mod that can be returned to stock if desired. The letters are available and the biggest risk is damage to the small section of deck lid stripe vinyl. Link to comment Share on other sites More sharing options...
chuckstang Posted July 14, 2007 Report Share Posted July 14, 2007 What exactly did you all use to pry the old letters off? Please be specific as Im a bit dense and would like to do it right hahahahaah I have been looking at my new set for way too long and they need to go on the back like they should have all along. Link to comment Share on other sites More sharing options...
TexasShelby Posted July 14, 2007 Report Share Posted July 14, 2007 You think you're dense ... The key word for me was patience. A good blow dryer, a plastic putty knife, some strong fishinig line and a little Goo-Gone will take them off. Very slowly heat up one letter at a time, I put the edge of a microfiber cloth on the paint and tried prying very slowly with the putty knife, not wanting to mar the paint. Didn't work too well, at first, buy after you get an edge up it does. So I would heat and slide the fishing line with a little Goo-Gone and work it back and forth, then get the putty knife underneath. That was the easy part for mine, they had been on a while. The hard part for me was getting all the adhesive off the paint....that took about 30 minutes. Then I washed down the entire area with a sponge, RO water and dawn. Then clay barred it. After installed the new letters I went back with a few coats of wax/ICE. What fine scratches I had from removing the letters went away during the clay bar and ICE applications. And speaking of ICE. When I brought my Shelby home, I immediately put about 6 coats of Meguiar's Gold paste on her. It is a great wax, BUT, with only hand washing with filtered water and very mild soap, the wax wasn't holding up as good as I thought it should. I switched to Turtle ICE paste and liquid and the spray detailer. Wow...what a difference. The car doesn't even look the same. It's like you put another coat of clear on it. Plus the bugs just fall off. I use it on all the black plastic and under the hood as well....no haze or dust. When I take the bugs off, Then I go back with a quick coat of the liquid on the leading edges. I've always done the towel test on the hood of my cars when it's waxed. I'm telling you...you can't put anything on the hood now, it's that slick and that smooth. Hope this helps. Link to comment Share on other sites More sharing options...
chuckstang Posted July 14, 2007 Report Share Posted July 14, 2007 Hey thanks, I too used the Ice and did not get the same results. Not very impressed. I did not use the paste though just the liquid polish/wax. Did you use the MM measurements from the KR concept that someone else posted? They showed 30mm wide for the key hole in the center and I am not getting that same measurement. Why do you need to heat them up slowly? Link to comment Share on other sites More sharing options...
Mark25 Posted July 14, 2007 Report Share Posted July 14, 2007 I remember reading that the reason they didn't space out the lettering on the rear deck was because they felt that the lettering might not hold well on the vinyl striping. Might look a bit funny going around with ELBY or SH LB, etc., etc., Link to comment Share on other sites More sharing options...
cobrafan Posted July 14, 2007 Report Share Posted July 14, 2007 I remember reading that the reason they didn't space out the lettering on the rear deck was because they felt that the lettering might not hold well on the vinyl striping. Might look a bit funny going around with ELBY or SH LB, etc., etc., That was before they came out with the new "Super Sticky" (SS) flat black stripe. It has to do with some kind of new manufacturing and marketing scheme they came up with at SAI. They are convinced it will work for everybody. Link to comment Share on other sites More sharing options...
TexasShelby Posted July 14, 2007 Report Share Posted July 14, 2007 Hey thanks, I too used the Ice and did not get the same results. Not very impressed. I did not use the paste though just the liquid polish/wax. Did you use the MM measurements from the KR concept that someone else posted? They showed 30mm wide for the key hole in the center and I am not getting that same measurement. Why do you need to heat them up slowly? I put down about 4 coats of paste and off with a good buffer then a couple of the liquid. And like I said....very picky about the washing. I use the Mr. Clean car wash stuff. Our water is so incredible terrible here, it would probably strip the wax off itself. I started to use the measurements from the stripes, but discovered my painted on stripes were a couple millimeters wider, so it through the whole thing off. And two of the letters are different widths than the rest. So I pretty much eyeballed it and measures to center of each and allowed for the different widths of the two letters. If you have vinyl stripes, you shouldn't have any problem finding someone with the right set of numbers for you. Let me know if you need any help finding them. I think I have a pic of Grabber's measurements still around. Link to comment Share on other sites More sharing options...
Mark25 Posted July 16, 2007 Report Share Posted July 16, 2007 cobrafan, is the vinyl striping made by 3M? You're saying they've changed the coating to the striping in so that now the lettering will now adhere better? Link to comment Share on other sites More sharing options...
cobrafan Posted July 16, 2007 Report Share Posted July 16, 2007 cobrafan, is the vinyl striping made by 3M? You're saying they've changed the coating to the striping in so that now the lettering will now adhere better? Mark, Just taking a cheap shot at the "Flat Black" stripe issue, again. I got caught up in the Silver stripe (Surprise!) for the 40th Annivesary. Sent my deposit anyway, but I'm still not happy about changing out my stiripes. I think I read somewhere that Amy said that the stripes were being made for Shelby but I don't think she mentioned who the manufacturere was. If you post the question on her thread she is diligent about answereing questions. It would be a guess for me to say that one would provide a better surface for the letters to adhere to. Link to comment Share on other sites More sharing options...
1badsho Posted July 16, 2007 Report Share Posted July 16, 2007 Sweet... Mine are about the same spacing...but look different for some reason. All joking aside, I do like mine centered much better. that made me laugh ... good one ! Link to comment Share on other sites More sharing options...
