Need Engine Pics of SGT/SC Whipple Installs
comet78
Hey guys,
I'm having Whipple installed on 07 SGT and the finished install has the crossover fuel hose that connects the fuel rails together being routed directly over the top of my SC and it doesn't look good to me, is this the normal recommended way it should be installed? Are there any other options to reroute this hose without hurting performance? I would like you guys to post pics showing how your crossover fuel hose was routed on your Whipple installs, specifically looking for installs done through Shelby, thanks in advance for any help!
So the fuel line over the top is Whipples design so I will leave it that way. I saw someone with a Whipple on their KR on here and the fuel line is over the top as well. If the line is routed under the blower with the excessive heat it could cause premature line failure.
KR is a 5.4 and not a 4.6 so there is no cross over on top but here is the installation manual, on mine i have Fore Innovations fuel rails with teflon with stainless braided line
http://performanceparts.ford.com/download/instructionsheets/fordinstshtm-6066-05-10_gt.pdf
and more pictures but they are not of my car
http://www.nichepi.com/photos/Gaugeinstall/Boostgauge1.jpg
http://www.allfordmustangs.com/forums/attachments/2005-2010-mustang-talk/82943d1257722980-whipple-ho-tillman-speed-2006-mustang-gt-img_2118.jpg
The manual does say to route over the top and attach to other rail on page 36 of 97, step 98, 99
98. Install driver side fuel rail to engine, route rubber fuel line (PN# 46301950) over the supercharger and. Secure
fuel rail using the factory (2) 6mm bolts (8mm socket). Torque to 89 in/lbs.
99. Install supplied fuel line (PN# 46301950) to passenger side fuel rail barbed fitting. Secure with clamp (7mm nut
driver).
driver).
Good catch ... I have never seen that.
I did see that and thought oh well who am I to argue.... and I thought the original poster also found it somewhere....
