hodger Posted April 26, 2016 Report Share Posted April 26, 2016 Hi Guys Can anyone help me with a problem with a rear wheel sensor A year ago we fitted a rear wheel sensor The one sent was a new shaped one the others on the car are the banded ones .Trained the sensors all working fine Two weeks ago had two new rear-tyres fitted, started the car and the low tyre pressure light came on The one playing up was the new type sensor, so ordered a new one which was fitted, started the car same problem Tried training the sensors again but the new sensor will not peep I trained the wheels again and put it against the old one in my hand and it peeped Will work outside the car but not in the tyre Don't want to keep buying more sensors !!!! Any help will be most welcome Thanks Rob Hodge Link to comment Share on other sites More sharing options...
Hawkeye O'Saben Posted April 26, 2016 Report Share Posted April 26, 2016 those things are annoying. I would disconnect the whole system so it won't go off, but that's probably not the help you were looking for. What do the tire guys have to say about it? Link to comment Share on other sites More sharing options...
ilmor Posted April 26, 2016 Report Share Posted April 26, 2016 Hi Guys Can anyone help me with a problem with a rear wheel sensor A year ago we fitted a rear wheel sensor The one sent was a new shaped one the others on the car are the banded ones .Trained the sensors all working fine Two weeks ago had two new rear-tyres fitted, started the car and the low tyre pressure light came on The one playing up was the new type sensor, so ordered a new one which was fitted, started the car same problem Tried training the sensors again but the new sensor will not peep I trained the wheels again and put it against the old one in my hand and it peeped Will work outside the car but not in the tyre Don't want to keep buying more sensors !!!! Any help will be most welcome Thanks Rob Hodge Rob, I don't think you can mix types and have the system work. If your Mustang had banded then you must replace with banded, or go with all unbanded once confirmed what you choose is compatible with your Mustangs ECM. Link to comment Share on other sites More sharing options...
hodger Posted April 26, 2016 Author Report Share Posted April 26, 2016 those things are annoying. I would disconnect the whole system so it won't go off, but that's probably not the help you were looking for. What do the tire guys have to say about it? I think that might be the next thing to do really annoying Tyre guys don't know what to do apart from get another sensor, but all they will do is send me the same one !!!!! Link to comment Share on other sites More sharing options...
hodger Posted April 26, 2016 Author Report Share Posted April 26, 2016 Rob, I don't think you can mix types and have the system work. If your Mustang had banded then you must replace with banded, or go with all unbanded once confirmed what you choose is compatible with your Mustangs ECM. When I replaced the sensor a year ago they sent me the new type and said it was compatible with the banded ones , we fitted it and it worked great Not sure why it stopped working when we changed the tyre I may have to purchase a set of four as you said and try that ! Link to comment Share on other sites More sharing options...
shel-b001 Posted April 26, 2016 Report Share Posted April 26, 2016 When I replaced the sensor a year ago they sent me the new type and said it was compatible with the banded ones , we fitted it and it worked great Not sure why it stopped working when we changed the tyre I may have to purchase a set of four as you said and try that ! You c\n get a complete set along with training tool from American Muscle. check it out . Link to comment Share on other sites More sharing options...
hodger Posted April 27, 2016 Author Report Share Posted April 27, 2016 You c\n get a complete set along with training tool from American Muscle. check it out . Great thanks Link to comment Share on other sites More sharing options...
07gt500conv Posted April 27, 2016 Report Share Posted April 27, 2016 Rob, I don't think you can mix types and have the system work. If your Mustang had banded then you must replace with banded, or go with all unbanded once confirmed what you choose is compatible with your Mustangs ECM. Ilmor, That is not a true statement, I had one band go bad on my 500 shortly after buying car. Put the 2010 valve stem on ONE tire and it is still working fine with the three banded styles. Link to comment Share on other sites More sharing options...
BIKEBOY Posted April 27, 2016 Report Share Posted April 27, 2016 Link to comment Share on other sites More sharing options...
ilmor Posted April 27, 2016 Report Share Posted April 27, 2016 Ilmor, That is not a true statement, I had one band go bad on my 500 shortly after buying car. Put the 2010 valve stem on ONE tire and it is still working fine with the three banded styles. Link to comment Share on other sites More sharing options...
ilmor Posted April 27, 2016 Report Share Posted April 27, 2016 Glad to hear it worked for you. Link to comment Share on other sites More sharing options...
Voodoo Child Posted April 27, 2016 Report Share Posted April 27, 2016 Uhmm ... are those sensors manufactured/distributed by the same companies? Have you contacted the manufacturer rep/distributor to get an answer/explanation? or if you have someone that speaks Chinese ...call Ford's tire dept.!!! (I am on a emoticon fasting restriction... otherwise, I would have included a "rolling on the floor laughing" emoji!!!) Happy Hump Day! Link to comment Share on other sites More sharing options...
07gt500conv Posted April 27, 2016 Report Share Posted April 27, 2016 Uhmm ... are those sensors manufactured/distributed by the same companies? Have you contacted the manufacturer rep/distributor to get an answer/explanation? or if you have someone that speaks Chinese ...call Ford's tire dept.!!! (I am on a emoticon fasting restriction... otherwise, I would have included a "rolling on the floor laughing" emoji!!!) Happy Hump Day! Link to comment Share on other sites More sharing options...
Doug_GT350 Posted April 27, 2016 Report Share Posted April 27, 2016 Uhmm ... are those sensors manufactured/distributed by the same companies? Have you contacted the manufacturer rep/distributor to get an answer/explanation? or if you have someone that speaks Chinese ...call Ford's tire dept.!!! (I am on a emoticon fasting restriction... otherwise, I would have included a "rolling on the floor laughing" emoji!!!) Happy Hump Day! good point different manufacturers (countries) may not be compatible. It may have worked for Jim because of that..... why does it have to be so difficult.... I remember when getting a heater in the car was a huge selling item... Link to comment Share on other sites More sharing options...
hodger Posted April 27, 2016 Author Report Share Posted April 27, 2016 This is the sensor that was working with the banded ones We replaced it with a new one This one will peep in my hand when training but will not peep in the wheel Really frustrating Link to comment Share on other sites More sharing options...
07gt500conv Posted April 28, 2016 Report Share Posted April 28, 2016 I ordered mine from American Muscle. Then when I put on the Alclonas, I ordered from American Muscle again and all went well. Maybe being a different manufacturer like Doogs said, could be the problem Link to comment Share on other sites More sharing options...
hodger Posted April 29, 2016 Author Report Share Posted April 29, 2016 Thanks for your posts guys I think I will have to order a new one again Link to comment Share on other sites More sharing options...
