Best Sway Bar????
Beezykgt500
I have a 07 GT500,my front sway bar bushings are stock as well as the sway bar. The bushings are bad. I want to upgrade to a better sway bar,I know adjustable sway bars just have the 3 holes for stiffness but my question is who makes the best ones? The thicker the better?? All I want is minimal body roll,I don't go to the track,just an everyday driver. Thanks in advance...
I use the Hotchkis bars on 2007 - 2010 GT500 cars for both street and track. I also recommend the BMR Fabrication front tubular radiator support brace with the tabs that are used for the front sway bar mounting and use the 2011 - 2014 OEM sway bar end links. Because of the vertical mounting on the subframe to bar set up there is NO NEED to use an adjustable end link.
