nilrak Posted August 7, 2015 Report Share Posted August 7, 2015 I have a 2013 gt 500 with 40K on it. Recently I am having an intermittent problem with the electronic damper control. I will be driving normally and the shocks will go into sport mode with no input from the control switch. While the car is in motion the shocks will not return to normal driving mode regardless of pressing the control switch. When I come to a complete stop the shocks return to normal mode. The moment I engage the clutch and start rolling the shock symbol on the dash flashes and the dampers go back into sport mode. As stated this is an intermittent problem. Anyone else having similar problems or know where to look for a solution. Can't take it in for service if I am not sure I will be able to reproduce the problem. Thank you all.................. Quote Link to comment Share on other sites More sharing options...
nilrak Posted August 12, 2015 Author Report Share Posted August 12, 2015 Update. I have found out that if you shut down the car and the computer the problem will go away. So a reboot will resolve it temporarily............ Quote Link to comment Share on other sites More sharing options...
Imatk Posted August 19, 2015 Report Share Posted August 19, 2015 Update. I have found out that if you shut down the car and the computer the problem will go away. So a reboot will resolve it temporarily............ Man that sucks. Are you still under warranty? If so I'd take it in and have them take a look, I haven't heard of this before. Quote Link to comment Share on other sites More sharing options...
