Caster Camber Plates
Can the caster camber plates be used with the strut brace in place? I see Andrew has them on his SGT, but, others say the plates can't be aligned with the strut brace in place, so I am confused, Thanks for you help. Harley
Yes, they work the same whether you have a STB or not.
The plate moves UNDER the shock tower and the 4 bolts remain in the same place regardless of where you set the plates.
It's hard to explain but if you saw it, you'd realize how it works right away.
Phill
