Whats The Widest Safe Rear Tire Size For 2014 Gt500
I am looking to upgrade my rear tires to the michelin pilot super sports 315/35r20 for the rear. I have a stock stance 2014 Shelby Gt500 although the engine is a bit modified. Im trying to get as much down on the rear tires, but am curious since these are 12.4" wide if I will have any issues?
As Alibi mentioned, it can be done , but remember if the rim width is narrower than recommended, it defeats the purpose of the wider "surface patch" , because it doesn't flatten out appropriately and make contact anyway. The whole idea is to maximize the contact patch to the pavement for grip.
Are you aware that Ford had to knurl the inside of the bead on the rims so the tires no longer rotated on the wheel approaching 200 MPH? Ford discovered the valve stems were releasing air and the tires were rotating on the rims at speed. So if you change the rims and tires maybe you do not want to go too fast?
  • 4 weeks later...
Running P265 35ZR 20s front & P305 30ZR 20s out back and man do they look great. (2014 SVTPPATP Shelby GT-500).
