Richard Stiles Posted November 27, 2014 Report Posted November 27, 2014 I would like my 2014 stock GT 500 to sound like some of the blown hot rods. What did SVT do to it to eliminate this sound?
54First Posted November 28, 2014 Report Posted November 28, 2014 Those blown hot rods have a Gilmer drive belt. They have ribs that run across the belt instead of along the belt, and of course, pulleys to match. You'rehearing belt whine, not blower whine. If they're running gear cam drives instead of chain or belt, they whine also. Steve
tekheavy Posted November 28, 2014 Report Posted November 28, 2014 Take it up to a 100 mph with your wife or girlfriend in the car. You're guaranteed to hear a whine.
shel-b001 Posted November 28, 2014 Report Posted November 28, 2014 I have an `0& & it definitely has a whine to it .(eaton S.C)
americaniron Posted November 28, 2014 Report Posted November 28, 2014 When I upped mine to 20 psi, I got plenty of whine sound from it. It's all in the speed that the supercharger is turning.
54First Posted November 28, 2014 Report Posted November 28, 2014 You guys have obviously never heard a blown hot rod. They whine at idle, and loud. It's all in the blower drive. No GT500 whine is ever going to equal that. My '08 whines quite nicely, but it doesn't come close to the sound the OP wants. Steve
gotoatz Posted November 28, 2014 Report Posted November 28, 2014 Since your car is brand new, pretty sure you don't want to be doing a blower swap...... Just install a CAI and get a good tune from a reputable tuner......Big increase in whine......... Mike
shel-b001 Posted November 28, 2014 Report Posted November 28, 2014 You guys have obviously never heard a blown hot rod. They whine at idle, and loud. It's all in the blower drive. No GT500 whine is ever going to equal that. My '08 whines quite nicely, but it doesn't come close to the sound the OP wants. Steve Yes I have heard many blown Hot Rods in my years , I don`t think he was hoping to get that sound as he mentions about SVT doing something to the newer Shelbys . I believe the newer ones are quite a bit quieter.
54First Posted November 28, 2014 Report Posted November 28, 2014 I would like my 2014 stock GT 500 to sound like some of the blown hot rods. What did SVT do to it to eliminate this sound? Here's what he said. Steve
WJinLV Posted November 29, 2014 Report Posted November 29, 2014 The air intake just after the air filter has a baffle from the factory. Buy a resonator delete from Ford Racing and you will gear more whine.
Richard Stiles Posted November 30, 2014 Author Report Posted November 30, 2014 Thanks. I'll be installing the "resonator delete".
mavisky Posted December 1, 2014 Report Posted December 1, 2014 You'll only get the whine on these cars when on the throttle. You'll never get the whine at idle because the helical gears are designed to be quiet. A 34 coupe with a BDS 8-71 with a cog drive at your local hot rod show will whine like crazy at idle due to it's straight cut gears.
shel-b001 Posted December 1, 2014 Report Posted December 1, 2014 Here's what he said. Steve Ya but we all know that won`t happen , but he also said what did SVt do to the newer ones as they definately don`t make the same whine as the 07`-09`s
MY500SS Posted December 2, 2014 Report Posted December 2, 2014 Take it up to a 100 mph with your wife or girlfriend in the car. You're guaranteed to hear a whine. ...............now that's funny right there.
Alcan KobRa Posted December 3, 2014 Report Posted December 3, 2014 Add a smaller pulley, and remove the hood insulation. You'll definitely hear the whine. AK.
2010KonaBlueGT Posted December 3, 2014 Report Posted December 3, 2014 I would like my 2014 stock GT 500 to sound like some of the blown hot rods. What did SVT do to it to eliminate this sound? They added a resonator to the intake of the SC to help bring down the noise. When I ran the last Mojave Mile event I had a Go Pro mounted dead center of my upper grille. When I replayed it, ALL I can hear is blower whine. My neighbors son-in-law asked me if it was supercharged because he could hear the whine as I went by their house. Inside the car you're hearing the exhaust and most of the engine noise is canceled out with insulation. So the blower whine is there, you're just not hearing it from inside the car. Phill
Boris Bogdanich Posted December 3, 2014 Report Posted December 3, 2014 Kenne Bell Mammoth should fix that.
ITHERTZ66 Posted December 4, 2014 Report Posted December 4, 2014 They added a resonator to the intake of the SC to help bring down the noise. When I ran the last Mojave Mile event I had a Go Pro mounted dead center of my upper grille. When I replayed it, ALL I can hear is blower whine. My neighbors son-in-law asked me if it was supercharged because he could hear the whine as I went by their house. Inside the car you're hearing the exhaust and most of the engine noise is canceled out with insulation. So the blower whine is there, you're just not hearing it from inside the car. Phill This actually sounds like a great solution. I miss hearing the exhaust when driving my car.
Deadly Venom Posted December 18, 2014 Report Posted December 18, 2014 KB 2.8 and a 168 MM mono blade and you will hear the whine!
