jaydub Mach1 Posted October 7, 2014 Report Share Posted October 7, 2014 I have an '07 SGT that I bought new in September of 2007. It's my DD and has "only" 40k miles on it. My commute isn't very long. Recently, I've noticed that the clutch engagement point is getting farther and farther out. I called the dealer and he said it sounds like I need a new clutch. I've always taken it there for service. I try to take it easy on the clutch and 40k on a clutch seems a little soon My question is should I have them install the stock clutch? Or should I have them install a different one? I don't want to increase the pedal force, I like it just fine how it is now. Maybe one that won't wear as fast. Thanks in advance for any help! Link to comment Share on other sites More sharing options...
Doug_GT350 Posted October 7, 2014 Report Share Posted October 7, 2014 Personally if you indeed need a new one I would go for an aftermarket one. If the stock one wore out at 40K you will need another one at 80. I had a McLoed put in mine when I did the SC conversion and I didn't notice anything different in the pedal... just my .02. Link to comment Share on other sites More sharing options...
zachman Posted October 8, 2014 Report Share Posted October 8, 2014 Put McLeod dual disk in my 08 GT. It is also supercharged. Clutch pedal is just like stock. Little more money but works great. Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted October 8, 2014 Report Share Posted October 8, 2014 McLeod dual-disk installed after the supercharger - as light or lighter than stock clutch feel. Make sure you have a reputable mechanic do the install as some have had issues with clutch drag. As for your current clutch, is it slipping? Try passing someone in 5th gear - if you can hear the RPMs climbing, but your speed isn't, the clutch is beginning to slip. Ford says to start the car, place in high gear, then release clutch - if the engine stalls, clutch is OK, if it doesn't, clutch is bad! (Nothing like stating the obvious!) Sam Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted October 12, 2014 Author Report Share Posted October 12, 2014 McLeod dual-disk installed after the supercharger - as light or lighter than stock clutch feel. Make sure you have a reputable mechanic do the install as some have had issues with clutch drag. As for your current clutch, is it slipping? Try passing someone in 5th gear - if you can hear the RPMs climbing, but your speed isn't, the clutch is beginning to slip. Ford says to start the car, place in high gear, then release clutch - if the engine stalls, clutch is OK, if it doesn't, clutch is bad! (Nothing like stating the obvious!) Sam Thanks. I'll try that! Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted October 14, 2014 Author Report Share Posted October 14, 2014 Sam-- So, on the way home, yesterday, I stopped at the bottom of the hill at the beginning of our street. I put the car in 5th and let the clutch out slowly while giving it a bit of gas. It shuddered then stalled. Does that mean the clutch is fine? Link to comment Share on other sites More sharing options...
Rex B Posted October 29, 2014 Report Share Posted October 29, 2014 Your disk is getting thin, causing the engagement point to change. As long as it hooks up, no need to change it until it starts slipping. Link to comment Share on other sites More sharing options...
LuLu Posted February 20, 2015 Report Share Posted February 20, 2015 Sam-- So, on the way home, yesterday, I stopped at the bottom of the hill at the beginning of our street. I put the car in 5th and let the clutch out slowly while giving it a bit of gas. It shuddered then stalled. Does that mean the clutch is fine? Yup. Clutch is fine, given its mileage. Not sure what you expect for lifetime of a wear item, but at 40k, you got your money's worth. "If it ain't broke...blah, blah, blah". If you are still on the OEM clutch, how about those tires? If still OEM, I suggest you undertake a critical Inspection of all wear items, check tire tread depth twice. The weight distribution on the S197 frame is 55/35 front. Under hard braking it gets tail happy. Check this out before you learn the hard way? Link to comment Share on other sites More sharing options...
Kevin Patten Posted February 20, 2015 Report Share Posted February 20, 2015 Lulu, you might want to put your car on some scales - it's not 65/35 on the weight distribution. Link to comment Share on other sites More sharing options...
LuLu Posted February 21, 2015 Report Share Posted February 21, 2015 Typos are such great fun. Really. Just when I was thinking no one reads my posts... Link to comment Share on other sites More sharing options...
Kevin Patten Posted February 21, 2015 Report Share Posted February 21, 2015 Sam-- So, on the way home, yesterday, I stopped at the bottom of the hill at the beginning of our street. I put the car in 5th and let the clutch out slowly while giving it a bit of gas. It shuddered then stalled. Does that mean the clutch is fine? Just to get back on topic - It means that it's working properly and not slipping but if the disengagement point is changing then that's indicating wear of the clutch disc. JMO I would think that a clutch should last at least 65,000 miles +. Link to comment Share on other sites More sharing options...
TheKurgan Posted February 21, 2015 Report Share Posted February 21, 2015 The stock clutch is solid. I doubt it is worn with that mileage especially if it babied. I have a Spec now, but I have launched the stocker at the drag strip probably a couple hundred times smoked it very bad once thinking I was doing a burnout. When I pulled the engine, the disc was not bad at all. Link to comment Share on other sites More sharing options...
StangJunkie01 Posted July 13, 2015 Report Share Posted July 13, 2015 I have an Exedy stage 3. It's great in terms of performance but not so great for a DD. I would look at an Exedy stage 1. Comparable pedal feel to a stocker and little more in terms of holding capacity. Also stay with the stock flywheel or a chromoly. Aluminum sucks for the street due to its light light weight. Link to comment Share on other sites More sharing options...
