jcox07 Posted September 15, 2014 Report Share Posted September 15, 2014 Is the m-2353-a abs module compatible with the 2010 GT500 and if so is a tune required to make it work. I am having trouble with abs kicking in way early on my GT500. I auto cross it and it has started to have brake fad issues. We changed master cylinder and brake booster and it did not fix the problem and also changed out the brake fluid to a dot 4. I am running carbotech xp8 pads in the front and ax6 pads in the rear. This setup worked very well but some thing has changed. Is it possible that the pads can get glazed over? Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted September 16, 2014 Report Share Posted September 16, 2014 The M-2353-A module is NOT compatible with the 2010 GT500 or any other GT500. What master cylinder and booster are you using ? Brake fad is primarily a pad compound issue and pedal fade is a fluid issue. Quote Link to comment Share on other sites More sharing options...
