daytonprowler Posted August 13, 2014 Report Share Posted August 13, 2014 (edited) Does anyone know if the tail lights offered below cycle when the brake lights are pressed? I called SPP and I still don't feel 100% comfortable with the answer I got. When I press on the brakes I do not want the brakes lights to cycle, not even once. I want only the turn signal to cycle. http://www.shelbystore.com/product-p/110631.htm Thanks Edited August 13, 2014 by daytonprowler Quote Link to comment Share on other sites More sharing options...
grsybtch Posted August 13, 2014 Report Share Posted August 13, 2014 I've had these on my last two Mustangs and I know they can be hooked up either way very easily http://www.webelectricproducts.com/products.htm Quote Link to comment Share on other sites More sharing options...
Larry T Posted August 14, 2014 Report Share Posted August 14, 2014 My set I ordered from SPP and installed do cycle when the brake pedal is depressed. Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted August 14, 2014 Report Share Posted August 14, 2014 I've had these on my last two Mustangs and I know they can be hooked up either way very easily http://www.webelectricproducts.com/products.htm I have these too.... There is a telephone cord that runs between both, that when connected keeps the brake lights from doing what you don't like. I happen to agree with you and have the phone cord plugged in myself. I know this doesn't answer your question about an SPP part, but maybe you could ask them if theirs comes with a telephone cord? Quote Link to comment Share on other sites More sharing options...
Rattlesnake Posted August 14, 2014 Report Share Posted August 14, 2014 I bought mine some time ago from SPP and I ordered the programmable tail lights that are sequential. Mine will cycle once and then they are full brake lights and that's it.. I don't mind because the sequential flash is fast enough and the brake lights are bright enough.. And the center brake light comes on right away as well. Quote Link to comment Share on other sites More sharing options...
jerseygator Posted August 14, 2014 Report Share Posted August 14, 2014 I bought mine some time ago from SPP and I ordered the programmable tail lights that are sequential. Mine will cycle once and then they are full brake lights and that's it.. I don't mind because the sequential flash is fast enough and the brake lights are bright enough.. And the center brake light comes on right away as well. Exactly... Mine too. Quote Link to comment Share on other sites More sharing options...
