Ghoust Posted July 12, 2014 Report Share Posted July 12, 2014 Link to comment Share on other sites More sharing options...
Secondo Posted July 13, 2014 Report Share Posted July 13, 2014 Good job on the video and thanks for posting it for us!! Sounds great all around, especially from the rear of the car. What's up with the shifter bushings? Is that an issue with all years or just the '13-'14's? Link to comment Share on other sites More sharing options...
Ghoust Posted July 14, 2014 Author Report Share Posted July 14, 2014 I have heard that some 2010 and up GT500 guys (including myself) have an issue with the 2nd gear grinding when shifting at redline. Some say that this is due to the clutch spring assist and the softer bushings in the shifter making it sway. A lot of guys simply get an aftermarket shifter like a barton or MGW and call it a day. I like the stock shifter so this was my other option. Link to comment Share on other sites More sharing options...
Ray Lucca Posted July 14, 2014 Report Share Posted July 14, 2014 MRT off-road H, stock cat-back, or after market?? How is the Drone at freeway speeds?? Great job on the Video Link to comment Share on other sites More sharing options...
Ghoust Posted July 15, 2014 Author Report Share Posted July 15, 2014 Correct. I have the stock catback and there is no drone at freeway speeds. Link to comment Share on other sites More sharing options...
Torched10 Posted July 15, 2014 Report Share Posted July 15, 2014 Can you give us more info on bushings et al, product how to install etc Link to comment Share on other sites More sharing options...
Ghoust Posted July 18, 2014 Author Report Share Posted July 18, 2014 Here is a link to the bushings: http://www.revanracing.com/categories/2011-14-shelby-gt500/drivetrain/shifter-bushings.html The install is basically taking out the shifter as if you are going to swap out to a Barton or MGW unit and replacing the rubber bushings with the new solid steel ones. It firms up the shifter so it does not flex enough to produce the 1st to 2nd grind issue. Link to comment Share on other sites More sharing options...
