mikeljgt500kr Posted June 16, 2014 Report Share Posted June 16, 2014 I finally received my GT350 decorated shift knob from SPP, after several months on back order. It came with several nuts, etc. and no instructions or explanations about installing it on my 2013 GT350. I have tried to take off the existing white ball the car came with, but it will not budge. I hate to get my vise grips latched onto it and buger it up. Any tips on how this is held on? Is it just screwed on? Are there lock screws I am not seeing on it? Any tips welcome, thanks. Link to comment Share on other sites More sharing options...
BLUE 2010 SHELBY GT 500 Posted June 17, 2014 Report Share Posted June 17, 2014 its just like the gt 500 shift knob , its on there with red lock tight, and takes a lot of working it to get it off , but it does come off keep trying Link to comment Share on other sites More sharing options...
gotoatz Posted June 24, 2014 Report Share Posted June 24, 2014 When I did the knob on my 500, I ended up lifting the center console, unbolting the shift arm from the tranny, (2 bolts) and pulling the whole unit out of the car. Then you can put the shift knob between a couple of 2x4's in a vice, and use the shift arm as leverage with a big ass crescent wrench, and spin it loose...... Takes about 15 minutes tops. Better than breaking your existing shift ball...... Link to comment Share on other sites More sharing options...
cmcmotorworks Posted June 25, 2014 Report Share Posted June 25, 2014 I've found a leather strap wrench works the best. Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted July 4, 2014 Author Report Share Posted July 4, 2014 I've found a leather strap wrench works the best. Thanks much for that idea, I used one and it was very easy. Link to comment Share on other sites More sharing options...
cmcmotorworks Posted July 6, 2014 Report Share Posted July 6, 2014 No problem. I'm not just a trouble maker like some think. I can be of some help from time to time. Link to comment Share on other sites More sharing options...
CQGcarz Posted July 10, 2014 Report Share Posted July 10, 2014 Thanks much for that idea, I used one and it was very easy. Do you have the upgraded Barton shifter? I have tried to remove that knob and I cannot. Link to comment Share on other sites More sharing options...
cmcmotorworks Posted July 10, 2014 Report Share Posted July 10, 2014 Do you have the upgraded Barton shifter? I have tried to remove that knob and I cannot. If you have the Barton short shifter, don't bother to remove. The Gt350 shifter ball from Shelby will not fit it. And Shelby has no reducers/adaptors Link to comment Share on other sites More sharing options...
CQGcarz Posted July 11, 2014 Report Share Posted July 11, 2014 If you have the Barton short shifter, don't bother to remove. The Gt350 shifter ball from Shelby will not fit it. And Shelby has no reducers/adaptors Thanks for responding. Link to comment Share on other sites More sharing options...
