andrewnagle1964 Posted May 24, 2014 Report Share Posted May 24, 2014 Removed rear seats, etc.... to continue my DynaMat project (trunk is done) Not sure where on the parcel shelf to put the Dynamat on the top (inside of cabin) or the bottom ( inside of trunk) I will also be removing the kiddy seat tie downs and cutting holes to make rear cabin sub woofer vents Cant' decide to come at it from above or below, grind or drill Quote Link to comment Share on other sites More sharing options...
Larry T Posted May 24, 2014 Report Share Posted May 24, 2014 Looks good .... keep us up to date with the progress. Quote Link to comment Share on other sites More sharing options...
MJN Posted May 24, 2014 Report Share Posted May 24, 2014 From the picture it looks like it is just spot welded? If so why not just drill out the spot welds then can pry it right out maybe. Quote Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted May 25, 2014 Report Share Posted May 25, 2014 I used a similar material in my trunk and above wheel wells and under the rear seating area....made a world of difference. FYI for the most part this stuff does not work by blocking out sound so it does not really need to be perfectly butted together and taped. It actually works by dampening sound by adding weight to the thin sheet metal, that otherwise acts like the skin of a drum. Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted May 25, 2014 Author Report Share Posted May 25, 2014 used a spot weld cutter I bought at harbor freight for $5.00 drilled them out no problem and it fell right off Quote Link to comment Share on other sites More sharing options...
Jer Posted May 25, 2014 Report Share Posted May 25, 2014 I used a similar material in my trunk and above wheel wells and under the rear seating area....made a world of difference. FYI for the most part this stuff does not work by blocking out sound so it does not really need to be perfectly butted together and taped. It actually works by dampening sound by adding weight to the thin sheet metal, that otherwise acts like the skin of a drum. What he said. In one of my many lives (LOL), I worked at a recording studio design firm. We designed some of the world's best rooms. Dynamat is for resonance reduction, as stated above. Concentrate it close to the speakers or sources of noise generation (UCA mount, above the diff, etc…). Some people install 12-18" squares with the 6X8 speaker hole cut in it, so the speaker is mounted through it. It helps reduce rattles, especially in the door locations. For "blocking" sound, Auralex SheetBlok (basically a roll of heavily-leaded rubber or vinyl) is used. But the rule is, "If it isn't watertight, you've just wasted your time". Lots of small studios spend a fortune on the stuff, then forget the electrical outlets, HVAC vents, etc. Cash down the drain. As for "subwoofer vents": The sub box itself is designed to be either a bass reflex or acoustic suspension device, no venting is needed or beneficial. Jer Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted May 26, 2014 Author Report Share Posted May 26, 2014 Jer, Thanks for the advice. Hope you are doing well. Andrew Quote Link to comment Share on other sites More sharing options...
Blown Away Posted May 26, 2014 Report Share Posted May 26, 2014 Flashbacks from a couple of months ago... You'll notice the difference when done. I ended up using 61 sheets for my car, but used Hushmat instead. Dan Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted May 26, 2014 Author Report Share Posted May 26, 2014 (edited) Hole cut kiddy tie down trim ring trimmed Edited May 26, 2014 by andrewnagle1964 Quote Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted May 27, 2014 Report Share Posted May 27, 2014 and when you install this stuff....wear gloves and be prepared for how sharp the cut pieces are......uggghhhhhh sliced hands suck Quote Link to comment Share on other sites More sharing options...
Blown Away Posted May 27, 2014 Report Share Posted May 27, 2014 and when you install this stuff....wear gloves and be prepared for how sharp the cut pieces are......uggghhhhhh sliced hands suck That's the best part about Hushmat, it doesn't cut your hands and is easy to install. No roller needed either, I just used a micro fiber rag to work the sheets down into place. Dan Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted May 28, 2014 Author Report Share Posted May 28, 2014 Kiddy tie down cover gone got tired of not being able to play music from my iphone, so since i had the back apart bought the USA-Spec interface, works great used the RCA out puts since I have a iphone 5 and the cable is for a 4 and did not want to spend $30 on an adapter plugs into between the Sirius controller in the trunk and the radio and have enough cable to put the control unit under the front seat More Dynamat Lifesaver torx wrench Quote Link to comment Share on other sites More sharing options...
RmGardner Posted July 1, 2014 Report Share Posted July 1, 2014 Will using these products on the rear trunk and between the struts help to quite the road noise. Rick Gardner Quote Link to comment Share on other sites More sharing options...
Blown Away Posted July 1, 2014 Report Share Posted July 1, 2014 I did pretty much the whole car in Hushmat, minus the roof, and it made it BIG difference in road noise. Quote Link to comment Share on other sites More sharing options...
REDTAIL Posted July 1, 2014 Report Share Posted July 1, 2014 FYI they make a drill bit designed just for spot weld removal. Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 1, 2014 Author Report Share Posted July 1, 2014 FYI they make a drill bit designed just for spot weld removal. Correct I got a cheap one at harbor freight since I only had 8 to do worked great (see post #5) Would have spent more but couldn't find a USA made one locally on a Saturday. Quote Link to comment Share on other sites More sharing options...
slbgtsc Posted May 19, 2015 Report Share Posted May 19, 2015 Andrew how did the dynamat project turn out? Just did my trunk and drivers side door. Waiting for the rain to clear so I can turn the car around and do the passenger door. Quote Link to comment Share on other sites More sharing options...
