rcbGT500 Posted May 16, 2014 Report Share Posted May 16, 2014 Hello, I have a 2013 GT500 w/Track Pack. Working on installing the Billet Fays2 Watts Link and have a couple questions about fitting the Axle Mounts: The drivers side has a bolt on top of axle The passenger side has a screw that holds a Diff Therm wiring clip. I can get the Drivers side bracket to clear the bolt (1/4 inch to outside). On the Passenger side, I removed the plastic clip that connects to screw, and can mount the bracket but to 45 degree downward minimum. I curious what others have done. Did you remove the screw entirely (hacksaw) to get more flexibility with passenger bracket. How critical is the angle (4:00 in instructions vs 45 degrees with screw in place) Spoke to Jim today, he wasn't familiar with the Track Pack axle. Thanks,Ron Link to comment Share on other sites More sharing options...
Triumph Posted May 18, 2014 Report Share Posted May 18, 2014 I installed a Fays 2 this week on my 07. I would file the remainder of the screw off. My passenger side mount is angled roughly at 45°. You will have to rotate it to make the arm level. Ultimately you want the arms equal lengths, parallel to the axle ( all with the suspension loaded) and the pivot clocked on the bottom between 6&7. If I said anything wrong I'm sure Albino or Viper will chime in... Link to comment Share on other sites More sharing options...
