Chair_Force_One Posted May 16, 2014 Report Share Posted May 16, 2014 So yesterday I installed an Engine Start button in my 09, All went well and the instructions were pretty clear. However today when I took a drive the Airbag warning light illuminated on the dash? What could be causing this? is it the bag on the steering wheel or the drivers seat? any insight would be much appreciated. Rich Link to comment Share on other sites More sharing options...
SSGT500 Posted May 17, 2014 Report Share Posted May 17, 2014 Does the light flash a code when you first turn the key on? If so, that will tell you where to look. Link to comment Share on other sites More sharing options...
Chair_Force_One Posted May 18, 2014 Author Report Share Posted May 18, 2014 Does the light flash a code when you first turn the key on? If so, that will tell you where to look. the light blinks for a few minutes then goes solid. is that what you mean? Link to comment Share on other sites More sharing options...
ViperNC Posted May 18, 2014 Report Share Posted May 18, 2014 By chance did you happen to have anything sitting in the passenger seat? Link to comment Share on other sites More sharing options...
Chair_Force_One Posted May 18, 2014 Author Report Share Posted May 18, 2014 no, not passenger seat related... its the main light on the dash Link to comment Share on other sites More sharing options...
SSGT500 Posted May 18, 2014 Report Share Posted May 18, 2014 The air bag light may be displaying a fault code. That code will direct you to the problem area or failed component. Count the flashes. It probably will be a two digit number. After you determine the fault code, do a google search for it. For example, a code 33 might be a failed passenger seat sensor or wiring. You can then check that wiring. Link to comment Share on other sites More sharing options...
msb64 Posted May 18, 2014 Report Share Posted May 18, 2014 Wonder if an OBDII scanner would list that fault? If so, and you have something like that or an SCT tuner, that could help pinpoint the issue. Last year I used my cars' SCT tuner on my Ranger truck to help diagnose an evap solenoid issue. Worked great and the cost of repair was less than $1 worth of solvent to free up the sticking solenoid. Link to comment Share on other sites More sharing options...
