Am I Missing Something On My Uca?
frazierfreud
I heard a bumping sound coming from the drivers side rear of my car. After backing my car onto some ramps I noticed my panhard bar bolt was quite loose. I threw some blue loctite on it and torqued it down to spec. I was then just checking the differences in this car compared to my 09' underneath the rear. A lot is the same, but there a lot of differences as well. Then I noticed my UCA where it connects the the car and it appears to be missing a bolt! There should be a bolt here, right?!
http://i1361.photobucket.com/albums/r671/mark_lejsek/48DA6CAA-6BCF-45CB-9CAF-4DFFC96E3956_zpsdhbzvi4v.jpg
There is a bolt there! It comes down from the top (under the rear seat) The UCM has the threaded portion - what you're seeing is the blind end portion of said bolt coming through the UCM . At least that's what I'm seeing here.
I meant a missing nut. I see what you are saying. It seems like on my 09' there were two different bolts coming through as opposed to the one bolt I the 13'. So the UCM serves as the nut I suppose?
