Chono88 Posted February 16, 2014 Report Share Posted February 16, 2014 ok so I have a nasty squeak in the rear of my car. The squeak comes and goes but most of the time it's there. If I take a right turn the noise goes away(loading the left side) and if I take a left turn the squeak gets worse (loading the right side). it's not a constant squeak but as if the brake was going bad, I have just replaced the rear brakes about a month ago so I know it's not that. If i put my car on stands I can push and pull on the wheel and it has about 1/4 inch give in it (back left wheel) and the right side has very little to no give. I have ensured that the lugs are on evenly and to spec tight. Please help me narrow this down so I can get rid of this annoying/embarrassing squeak. Quote Link to comment Share on other sites More sharing options...
ilmor Posted February 16, 2014 Report Share Posted February 16, 2014 (edited) My first guess would be rear sway bar bushings. Edited February 16, 2014 by ilmor Quote Link to comment Share on other sites More sharing options...
Chono88 Posted February 16, 2014 Author Report Share Posted February 16, 2014 as the wheels are turning the squeak is very consistent as if the rotor was warped in a small spot causing it to rub, If I apply the brakes it also goes away. Quote Link to comment Share on other sites More sharing options...
ViperNC Posted February 16, 2014 Report Share Posted February 16, 2014 (edited) I had an issue with the rubber bushings at the rear shock towers. A little WD 40 and problem solved. Edited February 16, 2014 by ViperNC Quote Link to comment Share on other sites More sharing options...
Chono88 Posted February 16, 2014 Author Report Share Posted February 16, 2014 ViperNC-I have had this problem for about 3 weeks now, and on 14FEB14 I upgraded my suspension so the shock tower bushings have been replaced with Koni bushings. Quote Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted February 17, 2014 Report Share Posted February 17, 2014 Start the process of elimination, WD40 your rear sway bar bushings pretty good and see if that helps first. Then move on to your next thought......... GG Quote Link to comment Share on other sites More sharing options...
