yell03 Posted December 18, 2013 Report Share Posted December 18, 2013 For my 50th birthday I am getting a new set of rims for my Daily Driver 2011 GT500 Convertible making around 600rwhp after the TVS swap.It currently runs 285/35/19 Michelin Pilot A/S 3s out back which are GREAT tires in any weather.When Spring comes, I was thinking of swapping to Michelin Pilot Super Sports for the warmer weather, Spring & Summer and using the A/S 3s for the cooler months.Would the Super Sports provided better traction in warmer weather than the A/S 3s, talking straight line traction of course?The rims I am leaning towards are 19x9.5" SVE drifts which weigh about 26lb each, about 5lbs lighter than stock I believe. Quote Link to comment Share on other sites More sharing options...
BlueEyedSnake Posted January 11, 2014 Report Share Posted January 11, 2014 I would do 19's in the front and 20's in the back. But I assume you want to get 4 19's so you can rotate your tires and get more miles out of them. I currently have super sports on my GT500. I have 275/35/19 in the front and 295/35/20 on the back. Before this set I had the stock Goodyears and they were hot garbage. These SS blow those tires right out of the water. Traction is much improved and wheel hop is all but gone. For reference I do have Whiteline's LCA's with relocation brackets installed. But I had them also while I had the Goodyears on so it doesn't change anything. The car hooks up and go's. I thought I wanted to get the NT05's, but there is no way that you get the same mileage out of those as you would from the Super Sports. Seeing how this is your daily driver, I would recommend the SS's as I also daily drive my GT500. Quote Link to comment Share on other sites More sharing options...
yell03 Posted January 11, 2014 Author Report Share Posted January 11, 2014 I would do 19's in the front and 20's in the back. But I assume you want to get 4 19's so you can rotate your tires and get more miles out of them. I currently have super sports on my GT500. I have 275/35/19 in the front and 295/35/20 on the back. Before this set I had the stock Goodyears and they were hot garbage. These SS blow those tires right out of the water. Traction is much improved and wheel hop is all but gone. For reference I do have Whiteline's LCA's with relocation brackets installed. But I had them also while I had the Goodyears on so it doesn't change anything. The car hooks up and go's. I thought I wanted to get the NT05's, but there is no way that you get the same mileage out of those as you would from the Super Sports. Seeing how this is your daily driver, I would recommend the SS's as I also daily drive my GT500. I just put on Black AMR rims today, 19x8.5 front and 19x10 rear. I am ordering MPSS 255/40/19s and 295/35/19s. I might need to lower the car as the 8.5s make the front tires taller and the 10s make the rears shorter than the stock 9.5" rims. It makes the rear wheel gap huge. Quote Link to comment Share on other sites More sharing options...
awakeinAZ Posted January 11, 2014 Report Share Posted January 11, 2014 Looks good! I just upgraded to A/S 3 last week on the rear and they are great, very sticky! Quote Link to comment Share on other sites More sharing options...
yell03 Posted January 11, 2014 Author Report Share Posted January 11, 2014 Looks good! I just upgraded to A/S 3 last week on the rear and they are great, very sticky! I am going to give the A/S 3s to my son for the spring, summer, and fall. I gave him my stock rims. In the winter I will run the A/S 3s, they are amazing tires in the cold, and still very good in warm weather, but with 600rwhp, if the MPSS are any better I will take all the traction I can get. Quote Link to comment Share on other sites More sharing options...
BlueEyedSnake Posted January 12, 2014 Report Share Posted January 12, 2014 I just put on Black AMR rims today, 19x8.5 front and 19x10 rear. I am ordering MPSS 255/40/19s and 295/35/19s. I might need to lower the car as the 8.5s make the front tires taller and the 10s make the rears shorter than the stock 9.5" rims. It makes the rear wheel gap huge. You might want to try a 265/35/19 on the front. It will fit. I have a 275/35/19 on the front. There is a gap there and I will be lowering my car next week. I'll post pic's once it's done. Quote Link to comment Share on other sites More sharing options...
