Elgin Black Posted October 19, 2013 Report Share Posted October 19, 2013 (edited) I just got my car back from having the whipple 550 upgrade installed. Man what a difference. I have one question. The intercooler tank that came with the kit mounted next to the radiator tank instead of the drivers side fender. I have aluminum tanks for the radiator and the power steering. I can't find a tank with the same inlet and outlet locations that will fit in that area. Any suggestions? I may have to get the tank Lethal Performance has and reroute the inlet and outlet hoses. Edited October 19, 2013 by slygray1 Quote Link to comment Share on other sites More sharing options...
William Rodgers Posted October 19, 2013 Report Share Posted October 19, 2013 Congrats!!!!!!! I love mine, I can not help with your question. Did you keep the 4.10 gears? Mine is already to quick to get traction, I would think 4.10's would be worse. Quote Link to comment Share on other sites More sharing options...
Elgin Black Posted October 19, 2013 Author Report Share Posted October 19, 2013 yes I kept the 4:10's,holy smoke it was quick before but I will have to do something later. The IC tank mounts on the radiator shroud instead of on the drivers side tower. Quote Link to comment Share on other sites More sharing options...
SGT0128 Posted October 19, 2013 Report Share Posted October 19, 2013 Pics???? Quote Link to comment Share on other sites More sharing options...
ITHERTZ66 Posted October 20, 2013 Report Share Posted October 20, 2013 Congratulations - it's an awesome upgrade! Quote Link to comment Share on other sites More sharing options...
americaniron Posted October 21, 2013 Report Share Posted October 21, 2013 I went with the Lethal one. Matched the Moroso ones really well. Quote Link to comment Share on other sites More sharing options...
Elgin Black Posted October 21, 2013 Author Report Share Posted October 21, 2013 I also like the Lethal one. Did you have to change out your hoses? My tank is mounted on the radiator shroud. It seems the changed the tank mounting location with the kit I got. It also looks like the tank is bigger than the one they show in the picture when you order the kit. The hoses that came with mine are bent(formed) to fit the front mounted tank and I have been unable to find a tank with the inlet and outlet locations in the same locations as the one I received. Quote Link to comment Share on other sites More sharing options...
americaniron Posted October 22, 2013 Report Share Posted October 22, 2013 I also like the Lethal one. Did you have to change out your hoses? My tank is mounted on the radiator shroud. It seems the changed the tank mounting location with the kit I got. It also looks like the tank is bigger than the one they show in the picture when you order the kit. The hoses that came with mine are bent(formed) to fit the front mounted tank and I have been unable to find a tank with the inlet and outlet locations in the same locations as the one I received. It's been some time ago since I changed it out, but I do remember having to redo the hoses. I got some hoses from the parts store and figured out how to best route them to the fender area. I remember it was definitely an easy job. Quote Link to comment Share on other sites More sharing options...
Jer Posted November 1, 2013 Report Share Posted November 1, 2013 I just got my car back from having the whipple 550 upgrade installed. Man what a difference. I have one question. The intercooler tank that came with the kit mounted next to the radiator tank instead of the drivers side fender. I have aluminum tanks for the radiator and the power steering. I can't find a tank with the same inlet and outlet locations that will fit in that area. Any suggestions? I may have to get the tank Lethal Performance has and reroute the inlet and outlet hoses. http://www.shelbystore.com/product-p/s7m-8080-d.htm Jer Quote Link to comment Share on other sites More sharing options...
Elgin Black Posted November 1, 2013 Author Report Share Posted November 1, 2013 Jer, will this tank mount on the radiator shroud between the radiator tank and the power steering reservoir on Shelby GT? Quote Link to comment Share on other sites More sharing options...
Jer Posted November 1, 2013 Report Share Posted November 1, 2013 Power steering tank gets replaced and relocated to driver's side strut tower... Jer Quote Link to comment Share on other sites More sharing options...
