Oil seepage
mash
Sweating oil? Never heard of that and I have been working on cars as a hobby since 1965. Mine does not "sweat" oil anywhere.
And certainly not from the EXHAUST!!!
If OIL is leaking around the EGO sensor, you have more problems than just a sensor seal/gasket.
Phill
If it causes any stain on the floor that is not acceptable by anyone's standards for a new car. Escalate the issue up the Ford chain until it is fixed.
It is probably water that condenses in the exhaust and mixes with soot that lines the pipes. It will leave a black spot on the floor but still, it should NOT be leaking around (or before/upstream of) the EGO sensor.
That will allow It to pick up free oxygen which tells the PCM it's running lean and the PCM will falsely richen up the AFR and create all kind of problems.
Phill
Phill
I agree with Phill. Very doubtful it's an "oil" leak.
