jsimmons Posted July 10, 2013 Report Share Posted July 10, 2013 So far, I've made the following minor suspension changes to my base V6: Eibach Pro springs Koni Str.T struts/shocks Eibach adjustable sway bars SR Performance adjustable rear LCAs Whiteline LCA relocation brackets Steeda front LCAs Steeda bump-steer kit Next week, I'll be installing a Fays2 watts link (replacing my existing Whiteline panhard bar brace and FRPP adjustable panhard bar). I realized the other day that the only component on the suspension I have not yet replaced is the rear upper control arm. Once the watts link is installed, the car will be ready for some autocross fun. I've also replaced the OEM rotors with GT slotted/dimpled rotors and installed Hawk HPS pads and replaced the original fluid with ATE Super Blue, and swapped in a set of 3.73 gears. Yeee-haw! Link to comment Share on other sites More sharing options...
RUFDRAFT Posted July 10, 2013 Report Share Posted July 10, 2013 Awesome! Engine mods? Link to comment Share on other sites More sharing options...
jsimmons Posted July 11, 2013 Author Report Share Posted July 11, 2013 Awesome! Engine mods? Just a CAI and a tune. The car also has longtubes and a 2.5-inch stainless cat-back system on it, as well as an aluminum driveshaft. The only way I could really improve the drivetrain is by swapping in a V8 and manual transmission, but then I'd lose the weight advantage of being a V6. The car is stupid fast for a V6 as it sits (thanks to the 3.73 gears), and it handles like it's on rails now that I've done the bumpsteer kit and front LCAs. I'm pretty excited about getting the watts link. I do all of my own work on the car (except the gear swap), and the car is a daily driver. Link to comment Share on other sites More sharing options...
RUFDRAFT Posted July 11, 2013 Report Share Posted July 11, 2013 You've done your homework! Any pics from the track? Link to comment Share on other sites More sharing options...
jsimmons Posted July 11, 2013 Author Report Share Posted July 11, 2013 You've done your homework! Any pics from the track? I haven't been to an event yet. The next one is next Saturday, but I don't want to rush the watts link install (I'd rather do it right rather than fast), so it looks like next month is almost a sure thing. I should also have my harness and harness bar by then. Link to comment Share on other sites More sharing options...
RUFDRAFT Posted July 12, 2013 Report Share Posted July 12, 2013 Sounds like a plan -- keep us posted! Link to comment Share on other sites More sharing options...
jsimmons Posted July 18, 2013 Author Report Share Posted July 18, 2013 Took delivery of the Fays2 yesterday and I read through the instruction manual - it looks tedious, but certainly not hard. Should have it installed in about 2-3 hours. Had to go out and buy a digital level, and I'm gonna try to find appropriate Grade 8 bolts to replace the three Grade 5 parts that came with the kit.. Also got my RaceQuip 5-point harnesses and helmet (needed for autocross). Link to comment Share on other sites More sharing options...
RUFDRAFT Posted July 18, 2013 Report Share Posted July 18, 2013 Pics! Pics! Why upgrade the bolts? Link to comment Share on other sites More sharing options...
jsimmons Posted July 18, 2013 Author Report Share Posted July 18, 2013 Pics! Pics! Why upgrade the bolts? I saw someone mention that they bent the propeller bolt (I don't remember how they bent it, but I'm not going to take any changes. Grade 8 is always better than Grade 5.Besides Grade 8 has a zinc coating that inhibits corrosion. Link to comment Share on other sites More sharing options...
RUFDRAFT Posted July 19, 2013 Report Share Posted July 19, 2013 Check! Link to comment Share on other sites More sharing options...
jsimmons Posted July 22, 2013 Author Report Share Posted July 22, 2013 Writeup and a few pics If you're worried about NVH, don't be. If you get any, you installed it wrong. Took about 5 hours by myself in the driveway. I highly recommend that you replace your panhard bar/brace with a watts link (no matter what watts link manufacturer you chose, it's better than what you have now). The rear end feels even more planted than it did before. Link to comment Share on other sites More sharing options...
07gt500conv Posted July 22, 2013 Report Share Posted July 22, 2013 I highly agree. Put mine in around Feb and it was great on Tail of the Dragon. Really could feel the difference. Link to comment Share on other sites More sharing options...
RUFDRAFT Posted July 22, 2013 Report Share Posted July 22, 2013 Writeup and a few pics If you're worried about NVH, don't be. If you get any, you installed it wrong. Took about 5 hours by myself in the driveway. I highly recommend that you replace your panhard bar/brace with a watts link (no matter what watts link manufacturer you chose, it's better than what you have now). The rear end feels even more planted than it did before. Your website with install instructions is awesome! Link to comment Share on other sites More sharing options...
