Jer Posted July 2, 2013 Report Share Posted July 2, 2013 These links will take you to Installation Directions for most SPP products. I'm posting these here in the interim, while we work on our new Instructions web page. Jer http://info.shelbyamerican.com/Instructions/6R3Z-63424Z62-R.pdf http://info.shelbyamerican.com/Instructions/6-SpeedShifter%20-%20Gen%202%20(NEW).pdf http://info.shelbyamerican.com/Instructions/2010+ Wing Set.pdf http://info.shelbyamerican.com/Instructions/armrest_cover(05-09).pdf http://info.shelbyamerican.com/Instructions/Baer%20EP%206S%20Instructions%20(Front).pdf http://info.shelbyamerican.com/Instructions/Baer%20EP%206S%20Instructions%20(Front).pdf http://info.shelbyamerican.com/Instructions/battery_mount.pdf http://info.shelbyamerican.com/Instructions/bezel_lowershelbygt.pdf http://info.shelbyamerican.com/Instructions/BilletFuelDoor-Final.pdf http://info.shelbyamerican.com/Instructions/brakes_rear.pdf http://info.shelbyamerican.com/Instructions/camber_caster.pdf http://info.shelbyamerican.com/Instructions/control_arm(rearlower).pdf http://info.shelbyamerican.com/Instructions/control_arm(rearupper).pdf http://info.shelbyamerican.com/Instructions/conv%20boot%20installation%20instructions.pdf http://info.shelbyamerican.com/Instructions/gauge_pod.pdf http://info.shelbyamerican.com/Instructions/hoodpin_billet.pdf http://info.shelbyamerican.com/Instructions/hoodpin_radiatorcover.pdf http://info.shelbyamerican.com/Instructions/KA-6x8-SPEAKER.pdf http://info.shelbyamerican.com/Instructions/KA-8-WOOFER.pdf http://info.shelbyamerican.com/Instructions/KA-8-WOOFER-2010.pdf http://info.shelbyamerican.com/Instructions/KA-10-WOOFER.pdf http://info.shelbyamerican.com/Instructions/kicker_amp(2005-2009).pdf http://info.shelbyamerican.com/Instructions/kicker_amp(2010-2011).pdf http://info.shelbyamerican.com/Instructions/Mm5CC-6.pdf http://info.shelbyamerican.com/Instructions/panhard_bar.pdf http://info.shelbyamerican.com/Instructions/S5MK-16612-U.pdf http://info.shelbyamerican.com/Instructions/S6MK-2004-B.pdf http://info.shelbyamerican.com/Instructions/S7M-2005-C%20BrakeDuctPlate.pdf http://info.shelbyamerican.com/Instructions/S7MK-5490-C.pdf http://info.shelbyamerican.com/Instructions/S8M-2301-C_GT500KR_Fuel_Door_Instructions_05-09.pdf http://info.shelbyamerican.com/Instructions/S10MK-1447-C.pdf http://info.shelbyamerican.com/Instructions/S197%20Shelby%20instructions.pdf http://info.shelbyamerican.com/Instructions/ShelbyOilSeparator.pdf http://info.shelbyamerican.com/Instructions/shifter_installation.pdf http://info.shelbyamerican.com/Instructions/SPP%20PIAA%20Light%20Bezel%20Install.pdf http://info.shelbyamerican.com/Instructions/swaybar_endlink.pdf http://info.shelbyamerican.com/Instructions/taillightts_sequential(05-09).pdf http://info.shelbyamerican.com/Instructions/WideBodyInstruction.pdf http://info.shelbyamerican.com/Instructions/Wilwood%20Fitment%20Front.pdf http://info.shelbyamerican.com/Instructions/Wilwood%20Rear.pdf http://info.shelbyamerican.com/Instructions/S10M-2760-U.pdf Quote Link to comment Share on other sites More sharing options...
SGT0128 Posted July 2, 2013 Report Share Posted July 2, 2013 Very cool, thanks. Quote Link to comment Share on other sites More sharing options...
NordicShelby Posted July 3, 2013 Report Share Posted July 3, 2013 COOL Jer I think this is a VERY good idea. Thanks for posting this I am sure it will help many. Did you have instructions of the Shelby K-member? One little suggestion is if you could put the name of the part after the instruction link I think that would help people identify what exactly the instructions are for. Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted July 3, 2013 Report Share Posted July 3, 2013 Jer, Very helpful Thank you! Quote Link to comment Share on other sites More sharing options...
TurboGT Posted July 3, 2013 Report Share Posted July 3, 2013 Thanks Jer! Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted July 3, 2013 Report Share Posted July 3, 2013 These links will take you to Installation Directions for most SPP products. I'm posting these here in the interim, while we work on our new Instructions web page. Jer That is an EXCELLENT feature/idea! And it keeps me (and others) from having to hoard them on a HD. Phill Quote Link to comment Share on other sites More sharing options...
chronosafe Posted January 14, 2014 Report Share Posted January 14, 2014 Jer, The 2010+ wing set comes up as a 404 page not found. It might be because of the name of the file. Can you remove the +? Quote Link to comment Share on other sites More sharing options...
