steeda high flow inlet tube
bmezz
No, you don't need a tune. I've got the black version of that on mine and haven't done a tune yet. I really only did it for looks as I hate the stock intake hose, though I would imagine there are small gains as well given the design vs OEM. I did notice after I put it on that I could hear a little more intake noise when giving it throttle, but I like that.
Thanks now I'll go ahead and order it,also doing it for looks the stock in take hose belongs in a box stored away.
  • 2 weeks later...
Late to the party as always, but here's mine:
When i installed my elbow it hit my Moroso PS tank. Did you have to mod you tank to get the elbow to fit. I had to remove 1/2" from the mounting bracket sides and slot the mounting hole to get 1/4" clearance from the elbow. I don't think this is issue with the factory tank.
No, that's odd, huh? No problem at all.
My upper radiator hose, though, just barely kisses the matching Moroso overflow tank. I always check to make sure there is no wear on the hose.....
My PS tank is close and could probably stand to be modified like you did yours. I Haven't had any problems with it so it's not one of those pressing issues, but I would like a little more clearance for piece of mind. I'll use your specs to alter mine. thanks.
Jeff
  • 2 weeks later...
