reschlund Posted May 26, 2013 Report Share Posted May 26, 2013 My rev limiter is set at 5800rpm. I have tried to advance it to say 6000rpm. No go ! Is there a trick to getting to go past 5800? Or is that the limit ? No matter how many times I press to advance it stays at 5800rpm. I may need a new Flux Capacitor ! Thank You in advance WelderBob Link to comment Share on other sites More sharing options...
gotoatz Posted May 26, 2013 Report Share Posted May 26, 2013 Rev Limiter, or shift light? Are you talking about the rev limiter on an after market tune, and trying to adjust on your hand held? Mike Link to comment Share on other sites More sharing options...
reschlund Posted May 26, 2013 Author Report Share Posted May 26, 2013 No Sir, I am talking about the button you push on the left side of the steering wheel. Mine will not adjust past 5800. Link to comment Share on other sites More sharing options...
gotoatz Posted May 27, 2013 Report Share Posted May 27, 2013 The button to the left of the steering wheel only sets the shift light, or shift indicator. That would be the red "SVT" in the center of your tach....... It will go as high as 6500, then resets back to 1500. But this does not effect your rev limiter. It just adjusts the shift light. The rev limiter is factory set, and would only change with an after market tune and tuner.... Once you go thru the steps of getting the gauge to the shift indicator spot, then you have to hold down either the left or right button, to increase or decrease the setting of the shift light. It seems like you have to hold it forever, but probably more like 5 seconds or so......... Hope that helps, Mike Link to comment Share on other sites More sharing options...
dantesshelby Posted June 8, 2013 Report Share Posted June 8, 2013 reschlund flux capacir's are not recommended for servicing until the 100k mile marker Link to comment Share on other sites More sharing options...
1 Alibi 2 Posted June 8, 2013 Report Share Posted June 8, 2013 The rev limiter can be adjusted / reset in the tune. Link to comment Share on other sites More sharing options...
