SNKBITE Posted May 14, 2013 Report Share Posted May 14, 2013 Anybody devise a good way of redirecting the oil so it does not saturate the crossmember under the oil filter? Quote Link to comment Share on other sites More sharing options...
grsybtch Posted May 15, 2013 Report Share Posted May 15, 2013 I use a flexible cutting board .........Cheap and easy I wrap it halfway around the filter and use it to direct the flow into the drain pan They have them in the kitchen gadget section at the grocery store here Quote Link to comment Share on other sites More sharing options...
MJN Posted May 15, 2013 Report Share Posted May 15, 2013 What about zip lock baggie around the filter as you unscrew it catching the oil and the filter. Quote Link to comment Share on other sites More sharing options...
SNKBITE Posted May 15, 2013 Author Report Share Posted May 15, 2013 Thanks people. I knew a simple answer was out there somewhere Quote Link to comment Share on other sites More sharing options...
fcettner Posted May 16, 2013 Report Share Posted May 16, 2013 I use a sheet of alum foil and direct oil into pan. Quote Link to comment Share on other sites More sharing options...
Imatk Posted May 16, 2013 Report Share Posted May 16, 2013 I use the ziplock baggie procedure... works great Quote Link to comment Share on other sites More sharing options...
SNKBITE Posted May 20, 2013 Author Report Share Posted May 20, 2013 I use a sheet of alum foil and direct oil into pan. Like it, and used this method. It worked well.... Thanks to all who chimed in! Quote Link to comment Share on other sites More sharing options...
