ITHERTZ66 Posted May 13, 2013 Report Share Posted May 13, 2013 (edited) Does anybody else have any experience replacing the GT-H scuff plate inserts? I got a new set and despite efforts to really clean the Mustang scuff plate area, I'm having difficulty getting consistent adhesion of the inserts using the pre installed Shelby supplied mounting tape. As you may know, the Ford scuff plates are the same as the v6 and have an embossed plastic "MUSTANG" lettering design which doesn't allow a flat finish for anything to attach to: I'm getting buckling of the GT-H inserts because of this when trying to mount it flat and it won't stick. How did Shelby original mount these to avoid this problem? Anybody else having this problem? Too bad the inserts are not real rigid aluminum...more like a foil coated rubber. Edited May 13, 2013 by ITHERTZ66 Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 14, 2013 Report Share Posted May 14, 2013 more faux stuff. Mine are in great shape so I have not had to deal with this. Keep us posted as to what you learn. Quote Link to comment Share on other sites More sharing options...
REDTAIL Posted May 17, 2013 Report Share Posted May 17, 2013 did you ever get them intalled ? JIM Quote Link to comment Share on other sites More sharing options...
ITHERTZ66 Posted May 17, 2013 Author Report Share Posted May 17, 2013 They are installed, but they are not sticking. I guess I'll resort to gobbing up the area with lots of glue and hope it doesn't seep out and make a mess. I have also considered mounting the plates with trim spray adhesive to pieces of solid aluminum and then mounting that down to give it some rigidity so it will stick better? Problem is that raises the profile a little and exposes it potentially to actual scuffing damage (which is NOT hard to do to these parts). Quote Link to comment Share on other sites More sharing options...
GaryF Posted May 20, 2013 Report Share Posted May 20, 2013 I've replaced both of mine and didn't have a problem with them sticking properly/laying flat. Could be you got some bad 2-sided tape on yours. Have you asked for replacements just to check that theory? Quote Link to comment Share on other sites More sharing options...
ITHERTZ66 Posted May 20, 2013 Author Report Share Posted May 20, 2013 Gary, The first set I received had to be sent back for replacement as they had terrible shelf wear. I would rather not send back again - glad your experience was better than mine. Quote Link to comment Share on other sites More sharing options...
