magrag Posted April 25, 2013 Report Share Posted April 25, 2013 My 2008 GT550 with 24,000 miles just started to have the clutch slip today. Called my dealer service he said they never did a GT500 clutch and knew nothing (small town Shelby, Ohio). So I am thinking about doing it myself ?!?!? Can anyone help with the procedure and what all in involved? I have a lift available. I have done clutches before but nothing so new. Thanks Quote Link to comment Share on other sites More sharing options...
jnf Posted April 27, 2013 Report Share Posted April 27, 2013 As for the clutch, I just had mine replaced with a McLeod RXT. Very good clutch. After break-in, shifts are very smooth and precise. A real pleasure to drive. As for installing yourself, not sure. It seems quite involved. The tech had to drop the tranny, x pipe and drive shaft. Maybe you could find a driveline shop in your area. Good luck. Quote Link to comment Share on other sites More sharing options...
SteelSteeds Posted April 27, 2013 Report Share Posted April 27, 2013 I'm in the middle of this myself, and having trouble. I pulled the exhaust, driveshaft, wiring, starter and 5 out of 7 bolts. Can't seem to get at the top 2 bolts on the bellhousing. I've pulled the crossmember and tipped the whole assembly as far back as I can until the hoses/hardware behind the blower are crunching up against the firewall. When I get to those two bolts, all that's left is the hydraulic fitting from the slave cylinder. I've never done a hydraulic clutch before, not sure what to expect there either. I went with the Spec SS trim clutch after a lot of research. I've also got a new MGW shifter to go on, I wanted something a bit more precise than the Shelby 6 speed shifter I put on a few years ago. Quote Link to comment Share on other sites More sharing options...
SteelSteeds Posted April 29, 2013 Report Share Posted April 29, 2013 Here is my post with more observations: http://www.teamshelby.com/forums/index.php/topic/80699-need-some-advice-on-removing-my-transmission/ Quote Link to comment Share on other sites More sharing options...
scforsberg Posted April 30, 2013 Report Share Posted April 30, 2013 I just got the McLeod RST clutch and flywheel installed on my 09 and it is an excellent clutch. Great feel and very smooth. And can handle a lot of power. No issues as my daily driver. Quote Link to comment Share on other sites More sharing options...
