Gotboost? Posted April 18, 2013 Report Share Posted April 18, 2013 Hey guys I need help with installing the Shelby precut lower grill and the bezel kit. I'm test fitting the parts and I think something is wrong because on the backside of the lower grill shoudn't there be intake cylinder that I attach the brake duct hose to? As you can see from my pics I have nowhere to attach the hose. In fact, the correct brake duct kit from Shelby doesn't include any attachment that enables you to slide the hose over and clamp it. Thanks for the help. David Link to comment Share on other sites More sharing options...
89Saleen215 Posted April 18, 2013 Report Share Posted April 18, 2013 You've got them in right. What you are looking for is on the inside of the front "bumper" cover...the other end of the hole you're working on. Once you put that grille in place you'll see. Link to comment Share on other sites More sharing options...
TrakRat Posted April 18, 2013 Report Share Posted April 18, 2013 I assume you haven't pulled your existing grille off yet? Link to comment Share on other sites More sharing options...
Gotboost? Posted April 19, 2013 Author Report Share Posted April 19, 2013 Thanks for the confirmation and help. I'll post pics after I remove the bumper and complete the installation. David Link to comment Share on other sites More sharing options...
TurboGT Posted April 26, 2013 Report Share Posted April 26, 2013 Thanks for the confirmation and help. I'll post pics after I remove the bumper and complete the installation. David We're you able to complete the install? I was looking at the parts and wondering the exact thing you asked. Going to start the install this weekend so if you are able to post a pic of the connection it would be much appreciated. Link to comment Share on other sites More sharing options...
TurboGT Posted April 26, 2013 Report Share Posted April 26, 2013 I did a search & found several photos of the connection on the grille behind the bezels so that part shouldn't be hard. I will have to see how the routing of the duct around the heat exchanger goes though. Link to comment Share on other sites More sharing options...
fcettner Posted April 26, 2013 Report Share Posted April 26, 2013 Here's some pic's on how mine is routed on a KR. Link to comment Share on other sites More sharing options...
TurboGT Posted April 27, 2013 Report Share Posted April 27, 2013 Perfect - thanks! Link to comment Share on other sites More sharing options...
Gotboost? Posted April 28, 2013 Author Report Share Posted April 28, 2013 I installed the new lower grill and bezels Saturday. The duct work for the brakes didn't arrive so I'll tackle that another weekend. The install was fairly simple, but time consuming since it was my first time working on this generation of Mustang. BTW, thanks for all who contributed. David Link to comment Share on other sites More sharing options...
TurboGT Posted April 29, 2013 Report Share Posted April 29, 2013 Finished my install yesterday & everything went smoothly. The new front valance with the bezels really looks great. No issues at all routing the duct around the aftermarket HE. Would recommend putting a couple of dabs of RTV on the flange of the black plastic ring that clips to the bezel from behind the valance. I put a couple dabs where it contacts the back of the grill - although there are tabs that click to engage the bezel it seemed to me that they could come loose & allow the bezel to fall out. You can't see the RTV & the rings aren't going anywhere now. Also, the duct is a super tight fit on the circular vent behind the bumper & not much room for a hand in there. Just a thin smear of WD40 on the first inch inside of the tubing will make sliding it on there easier. Link to comment Share on other sites More sharing options...
motorjock205 Posted June 6, 2013 Report Share Posted June 6, 2013 I just installed one of these kits on my 2007 GT500, and I will say that the tubing routing is probably the hardest part...I cut the tubes just a little too short to start with, then had to get some pvc tubing to splice them back to gether at the front...but the black plastic piece that attaches to the front left wheel well was causing my tubing to kink and get caught between it and the rubber on the sterring arm...and it was crushing the tubing and the front tire would rub on the tubing at full lock...I finally got everything situated once I removed that small black plastic piece at the lower front of the fender well on the driver's side...didn't really see any practical purpose for it there anyway...wasn't anything on the right side like that at all...anyway, it is all done now, so I will carry on...Heading to the Legacy Bank Shelby show on June 22nd in Plano, TX...maybe I'll see some of you there. Link to comment Share on other sites More sharing options...
FiaCobra Posted June 9, 2013 Report Share Posted June 9, 2013 I did my install and everything went ok. The drivers side is a pain in the arse. It rubs if I turn the wheel all the way to the right. There's not much room to run the ducts on the left side (drivers side) Link to comment Share on other sites More sharing options...
