cleghornm Posted March 31, 2013 Report Share Posted March 31, 2013 I have 2013 Shelby with the Track PAC, is there any way to lower it, and keep the electronic ride control? Quote Link to comment Share on other sites More sharing options...
Farmer-Ted Posted March 31, 2013 Report Share Posted March 31, 2013 Sure, change the springs. Quote Link to comment Share on other sites More sharing options...
cleghornm Posted March 31, 2013 Author Report Share Posted March 31, 2013 Great FRRP or some other manufacture? Quote Link to comment Share on other sites More sharing options...
Twitch Posted March 31, 2013 Report Share Posted March 31, 2013 I just got Ford SVT Lowering Springs 1.25" (5300-L). Should work fine with the electronic suspension. Quote Link to comment Share on other sites More sharing options...
msw.63 Posted March 31, 2013 Report Share Posted March 31, 2013 I just got Ford SVT Lowering Springs 1.25" (5300-L). Should work fine with the electronic suspension. So when I look at these springs on the Ford Racing Parts website http://www.fordracingpartsdirect.com/FORD_RACING_SHELBY_GT500_1_25_IN_LOWERING_SPRINGS_p/m-5300-l.htm it says that they are recommended for use with the "Track Pack Option" because they are designed specifically for the "Bilstein electronically controlled Track Pack option." My reading of the 2013/2014 order guides has the Track Package (55S) with external engine, differential, and transmission coolers--nothing about Bilstein while the Performance Package (821A) has the "Bilstein cockpit-selectable dampers." This is simply a misprint on Ford's Racing Parts website and the SVTPP (821A) is the equipment package that the springs are designed for use with, correct? Quote Link to comment Share on other sites More sharing options...
Twitch Posted March 31, 2013 Report Share Posted March 31, 2013 Van at Revan Racing recommended them to me & said they would work fine with the electronically adjustable suspension...which is part of the SVTPP...not the track package. I have both the track package & SVTPP. Quote Link to comment Share on other sites More sharing options...
Twitch Posted March 31, 2013 Report Share Posted March 31, 2013 This thread has more details http://www.teamshelby.com/forums/index.php/topic/76706-ford-racing-lowering-springs-m-5300-l/ Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted March 31, 2013 Report Share Posted March 31, 2013 So when I look at these springs on the Ford Racing Parts website http://www.fordracin..._p/m-5300-l.htm it says that they are recommended for use with the "Track Pack Option" because they are designed specifically for the "Bilstein electronically controlled Track Pack option." My reading of the 2013/2014 order guides has the Track Package (55S) with external engine, differential, and transmission coolers--nothing about Bilstein while the Performance Package (821A) has the "Bilstein cockpit-selectable dampers." This is simply a misprint on Ford's Racing Parts website and the SVTPP (821A) is the equipment package that the springs are designed for use with, correct? You can't get the Track Package (TP) without getting the Performance Package (PP) so if you have the TP, you have the PP and shocks. Phill Quote Link to comment Share on other sites More sharing options...
msw.63 Posted April 1, 2013 Report Share Posted April 1, 2013 Van at Revan Racing recommended them to me & said they would work fine with the electronically adjustable suspension...which is part of the SVTPP...not the track package. I have both the track package & SVTPP. Thanks! Do you have these lowering springs? Did you install them yourself? What about getting your alignment checked after their installation? Quote Link to comment Share on other sites More sharing options...
Twitch Posted April 1, 2013 Report Share Posted April 1, 2013 I do have them. They are sitting in a box on my porch. Too scared to do it myself. I plan to get them, UCA, LCAs, & panhard bar installed all at once. I do think that an alignment would be in order after an install. Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 1, 2013 Report Share Posted April 1, 2013 I do have them. They are sitting in a box on my porch. Too scared to do it myself. I plan to get them, UCA, LCAs, & panhard bar installed all at once. I do think that an alignment would be in order after an install. You WILL need to at least check the alignment. Toe WILL be off. Camber may or may not be (USUALLY, not). Caster isn't something you can change so it matters not. Toe is a VERY important measurement. It will wear tires excessively and affect the way the car handles. Phill Quote Link to comment Share on other sites More sharing options...
