andrewnagle1964 Posted March 27, 2013 Report Share Posted March 27, 2013 (edited) So I finally made it to Pro-Dyno today; thanks to Craig G aka SGT/SC2873 for the recommendation. 2 hour drive to Charlotte, went down last night and had a 8 am appointment this morning Dan DeSio owner and operator of Pro-Dyno is just an awesome guy and knows his stuff. $375 out the door and we were there 6 hours. ( We had issues with the Nitrous bottle getting warm, it was 37 degrees outside. We never got enough bottle pressure to use the nitrous, so I will need to go back in the summer for the nitrous tune, this dyno is Naturally Aspirated) Final numbers are 356 RWHP 331 Torque NA Edited March 27, 2013 by andrewnagle1964 Quote Link to comment Share on other sites More sharing options...
jmn444 Posted March 27, 2013 Report Share Posted March 27, 2013 So is that without the nitrous? Not sure what you meant... Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 27, 2013 Author Report Share Posted March 27, 2013 So is that without the nitrous? Not sure what you meant... Correct those are NA numbers (no Nitrous) Quote Link to comment Share on other sites More sharing options...
jmn444 Posted March 27, 2013 Report Share Posted March 27, 2013 Very nice! How far up are you going to spin it with the nitrous on? Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 28, 2013 Author Report Share Posted March 28, 2013 Very nice! How far up are you going to spin it with the nitrous on? Looking to do a 125 shot Quote Link to comment Share on other sites More sharing options...
Carnut12 Posted March 28, 2013 Report Share Posted March 28, 2013 Great numbers for N/A!!!!!!! Quote Link to comment Share on other sites More sharing options...
jmn444 Posted March 28, 2013 Report Share Posted March 28, 2013 I meant rpm wise, but I suppose that will simply be when the 125 shot flat lines.... I'd be stoked with those numbers too though, pretty sweet! Quote Link to comment Share on other sites More sharing options...
stewarbc Posted March 28, 2013 Report Share Posted March 28, 2013 Nice numbers. What kind of exhaust are you running? Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 28, 2013 Author Report Share Posted March 28, 2013 I meant rpm wise, but I suppose that will simply be when the 125 shot flat lines.... I'd be stoked with those numbers too though, pretty sweet! Jason I should have actually read your question instead of blindly typing my answer. Not sure what you are asking but the nitrous will kick in at 3500 rpms and i will probably still shift at 6500. If that is what you meant. Hope you have been doing well. Andrew Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 28, 2013 Author Report Share Posted March 28, 2013 Nice numbers. What kind of exhaust are you running? Thanks American Racing Long Tube Headers 1 3/4” Hi-Flow cats and X pipe with FRPP Axle Back Mufflers “Stingers”M-5330-5GT Quote Link to comment Share on other sites More sharing options...
jmn444 Posted March 28, 2013 Report Share Posted March 28, 2013 Yeah, just meant what your shift point was planned on being... I don't know what kind of rpms the heads and aluminator will support, but figured with the nitrous you could peak a little higher maybe.... Things are good, just gotta make time to put the '68 back together for summer fun! Quote Link to comment Share on other sites More sharing options...
AndyGJ Posted March 28, 2013 Report Share Posted March 28, 2013 Sweet!!! Quote Link to comment Share on other sites More sharing options...
ilmor Posted March 28, 2013 Report Share Posted March 28, 2013 Congrats! You did it! Quote Link to comment Share on other sites More sharing options...
mywickedshelby Posted March 28, 2013 Report Share Posted March 28, 2013 Congrats Andrew, sweet numbers! Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 28, 2013 Author Report Share Posted March 28, 2013 Sweet!!! I am not sure how far you are from Charlotte but I think you might want to think through using him as your tuner Andrew Quote Link to comment Share on other sites More sharing options...
FILF Posted March 29, 2013 Report Share Posted March 29, 2013 What other mods are you running? Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 29, 2013 Author Report Share Posted March 29, 2013 (edited) What other mods are you running? 07SGT4623 Custom Tuned by Dan Desio Pro-Dyno AB Emblem Custom Dye Sublimated Visor Cover Afco High Performance Aluminum Radiator 4” Agent 47 Retro Side Mirrors American Racing Long Tube Headers 1 3/4” Hi-Flow cats and X pipe Amsoil Air Induction Filter EAAU6075-EA ARP Flywheel Bolts ARP Head Bolts ARP Crank Pulley Bolt ATE Super Blue DOT 4 Racing Brake Fluid Auto Meter Cobalt Nitrous Pressure Gauge Auto Meter Cobalt Oil Pressure, Fuel Pressure and Water Temp Gauges Auto Meter Cobalt A/F Wideband Gauge BMR Tubular K-Member (KM011) BMR Tubular A-Arms (AA019) BMR A-Arm Support Bar (AAS001) BMR Radiator Support (RS003) BMR Z-Brace (CB0004) BMR Panhard Bar Support (PHR007) BMR Drive Shaft Safety Loop (DSL010) Bob’s Auto Mustang KR Axel Reservoir Bosch 39lb Fuel Injectors Canton Coolant Expansion Tank Chip Beck Functional Hood Scoop Continental Extreme Contact DW Tires 275/40R18 DriveShaftShop One piece Aluminum Drive Shaft Exedy Mach500 Clutch Exedy 8-bolt Steel Flywheel FF Dynamics Slim Fan and Aluminum Shroud FordFan FRPP Tow Hook and Custom Bracket Fore Precision High Flow Fuel Rails Black Billet Aluminum Grabber Pony Custom Shift Knob Hurst Short Throw Shifter Innovators West Harmonized Balancer J&M Adjustable Upper Control Arm J&M Lower Control Arms with Relocation Brackets JPC Stainless Steel Racing Clutch line JTL Oil Catch Can Kenne Bell Boost-a-Pump 40 Amp Kenny Brown Jacking Rails Koni Yellow Adjustable Struts and Shocks Lethal 180 degree Thermostat Luminar 32% Black Window Tint Maximum Motorsports Adjustable Caster Camber Plates McGard Black Locking Lug Nuts Meziere Electric Water Pump Midwest Auto Painted Radiator Cover with Extensions Moroso Power Steering Fluid Reservoir Moroso Deep Sump Modular Oil Pan Optima RedTop® High-Performance AGM Battery PA Performance 6G Alternator 130 AMP Powder Coated White PIAA Sport Horns 115db 400HZ +500HZ PIAA Xtreme White Plus Bulb H13 PIAA 5192 Driving Lights PIAA Super Sporza Silicone Wipers POR15 Rust Treated and Painted Rear End Redline Elite Hood & Trunk Lid Struts Red Line 5W20 synthetic oil Roush Vent Gauge Pod SafeCraft Fire Suppression System LT10 Samco Silicone Coolant Hoses Shelby GT500KR Trunk Liner Shelby Billet Engine Caps Shelby Billet Under Hood Hardware Shelby Billet Black Hood Pins Shelby Billet Pedal Covers & Dead Pedal Shelby Berg Snake Faux Gas Cap Shelby Satin Chrome Quarter Light Trim Shelby Brake Cooling Kit Shelby Billet Black Grill Assembly Upper & Lower Shelby Carpeted Floor mats Shelby Grille Pony Emblem S&H Performance Oil Filter Relocation SHR Tru-Billet Fuel Door Black Anodized SHR Tru-Billet Lock Pocket Set and Door Pins SHR Tru-Billet Window Sill Plate SHR Tru-Billet Window Sill Plate SHR Tru-Billet Side Mirror Knob Black Anodized SHR Tru-Billet Power Point Plug Black Anodized SHR Quarter Window Louvers Painted Black SHR Trunk Release Button Speed of Sound Cup Holder Gauge/Switch Panel Speed of Sound Triple Dash Gauge Pod SS Inserts Air Brushed Fuse Box Cover Stage 8 Locking Header Bolts StangMods Clear Rear Side Marker Lenses w/ Red LED Bulbs StangMods Clear Turn Signal Lens w/ Stealth Bulbs Steeda Bumpsteer kit Steeda Front Street End Link Kit Steeda Carbon Fiber Intake Elbow Thump RRR Belt Tensioner and idler pulleys TSS Billet Gear Oil Pump UPR Shorty Antenna UMI Double Adjustable ChroMoly Panhard Bar (Rod Ends) Vogtland Lowering Sport Springs Web Electric Sequential Tail Lights Wilwood Superlite 6R Big Brake Front Brake Kit (Hat) & Superlite 4R Big Brake Rear Parking Brake Kit, 13” Rotors Drilled and Slotted and Stainless Steel Brake Lines Zex Nitrous System, Heater, Remote Bottle Opener, Blow Down Tube, Purge, Window Switch Painted on Stripes Satin Silver Paint code is M7049A Sherwin Williams #63454 SHELBY GT lettering is Myriad Pro Bold Italic 163 pt. Kicker Shelby Premium Audio System, 6x8" Speakers, 8" Door Mounted Woofers, 4.1 Channel Amplifier & 10" Subwoofer Ford Racing Performance Parts M-6009-A463 Aluminator Forged Internals 9.8:1 compression ratio M-9424-463V Intake Manifold M-6050-463P CNC Heads M-6550-3V Hot Rod High Lift Cams M-9926-3V Throttle Body M-6582-3VBLK Black Valve Covers M-4209-G410 4.10 Gears M-12405-3V12 0 degree Spark plugs M-5570-A Jounce Bump Stop Kit M-4033-G2 Axle Girdle Cover M-1007-S1895B1 Black SVT Wheel With Machined Lip M-1096-FR Ford Racing Center Caps M-5330-5GT Axle Back Mufflers “Stingers” M-20201-S197 Strut Tower Brace M-5490-A Sway Bars and Anti-Roll Bars M6731FL1A Racing Oil Filter Edited March 29, 2013 by andrewnagle1964 Quote Link to comment Share on other sites More sharing options...
FILF Posted March 29, 2013 Report Share Posted March 29, 2013 Jesus. I think you left out the fuzzy dice hanging from the rear view! Just kidding. Great list of mods! Make sure you update us when the nitrous is connected and tuned. I was looking to put that same kit on mine. Quote Link to comment Share on other sites More sharing options...
jmn444 Posted March 29, 2013 Report Share Posted March 29, 2013 So it's pretty stock eh??? LOL Quote Link to comment Share on other sites More sharing options...
07SGTC Posted March 29, 2013 Report Share Posted March 29, 2013 (edited) That's Awesome!!!!!!!!!!!!!!! Edited March 29, 2013 by 07SGTC Quote Link to comment Share on other sites More sharing options...
ccsl7578 Posted March 29, 2013 Report Share Posted March 29, 2013 Dan and all the guys at Pro-Dyno are awesome and they do GREAT work (check out their web page for all the services they provide) I highly recommend them to everyone! This is my local shop and I have had them do all of my mods and tuning. Well worth the drive for people out of state... you won't be disappointed!!! Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 29, 2013 Author Report Share Posted March 29, 2013 Jesus. I think you left out the fuzzy dice hanging from the rear view! Just kidding. Great list of mods! Make sure you update us when the nitrous is connected and tuned. I was looking to put that same kit on mine. I did forget the most important mod Escort 9500xi !!!!! Quote Link to comment Share on other sites More sharing options...
