JT93 Posted March 17, 2013 Report Share Posted March 17, 2013 Has anyone had any problems with the Shelby 8-Quart Pan? I'm thinking about putting it on the car when I change the oil this spring. I saw in the listing that it's powder coated, my first thought is that it would be easy for the paint to chip causing the pan to rust. http://www.shelbysto...s5se-6675-a.htm Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 17, 2013 Report Share Posted March 17, 2013 (edited) Been running the Moroso powder coat for years and no issues Edited March 17, 2013 by andrewnagle1964 Quote Link to comment Share on other sites More sharing options...
JT93 Posted March 17, 2013 Author Report Share Posted March 17, 2013 Is the Shelby pan the Moroso pan? They look identical, it'd be nice to know it's from a reputable manufacturer. Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 17, 2013 Report Share Posted March 17, 2013 Is the Shelby pan the Moroso pan? They look identical, it'd be nice to know it's from a reputable manufacturer. Can't remember if it the Moroso or the Canton either way you can't go wrong both good companies. Quote Link to comment Share on other sites More sharing options...
JT93 Posted March 23, 2013 Author Report Share Posted March 23, 2013 How much oil do you use, Andrew? I know the pan take 8 quarts, but what do you allow for the motor itself and oil filter? Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted March 23, 2013 Report Share Posted March 23, 2013 Has anyone had any problems with the Shelby 8-Quart Pan? I'm thinking about putting it on the car when I change the oil this spring. I saw in the listing that it's powder coated, my first thought is that it would be easy for the paint to chip causing the pan to rust. http://www.shelbysto...s5se-6675-a.htm I have one on my 2010 GT500 5.4L engine. It's POWDERCOATED, not painted so there is no paint to chip. A *good* powdercoat job is damn near impervious to chipping. Mine still looks brand new but in all fairness, i put very few miles per year on my car. It is debatable if the pan is Moroso or Canton. That was beat to death in another thread a year or two back and no one from Shelby would ever confirm either brand. I did have a problem when installing it and another TS member posted that he had the same problem. It wouldn't just slide up onto position onto the block because the oil pick-up sits slightly too far back and keeps it from being a slip fit. I removed the bolt for the pick-up tube bracket, pulled the pick-up screen over just a *hair*, put the pan up in place then replaced the bolt holding the tube in and went from there. Other than that, it was a perfect fit. You will also need a new gasket because they use a sealer on the seams for the front cover to the block, along the pan mating surface edge. Be prepared to pay well over 50 bucks for a new gasket (I bought locally for list/MSRP, didn't have time to purchase from Tousley). And I can't remember if you can get the pan in/out without dropping the K-member/subframe or not. I had mine dropped anyway so it didn't make a difference for me (I have a engine support brace left over from when I did it for a living). I can't tell you exactly how much capacity the engine holds now with the new pan because my oil changes have always been free. I know they never charged me extra for the added capacity and I know it was ALWAYS at the full mark when I picked it up so they did add the extra oil for free. The ad says the PAN holds 8-qts, not including the filter so my guess is 9-qts total. HTH, Phill Quote Link to comment Share on other sites More sharing options...
JT93 Posted March 23, 2013 Author Report Share Posted March 23, 2013 Was the oil pick-up 'problem' just a GT500 issue or will I run into the same thing with the 4.6? I wouldn't have an issue dropping the K-member, I'm getting ready to buy the Shelby K-member so I could just do everything at once. Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted March 23, 2013 Report Share Posted March 23, 2013 Was the oil pick-up 'problem' just a GT500 issue or will I run into the same thing with the 4.6? NO idea. And it might have only been a issue with the 2010 (the other guy had a '10 too). But really, it is NO big deal. Unscrew a bolt, hold the pan up, pull the pick-up aside (about 1/8"), slide the pan up, replace the bolt and tighten. Then put the pan up into place and hold with a bolt on each side near the middle so you can start all of the others. I put a K-member in too which is why I had the engine supported. It may have helped me install the headers too because I was able to take the motor mounts out of the way along with the K-member. Phill Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted March 24, 2013 Report Share Posted March 24, 2013 How much oil do you use, Andrew? I know the pan take 8 quarts, but what do you allow for the motor itself and oil filter? I am nearly 100% sure the pan does not hold 8 quarts but it increases the overall capacity to 8 quarts when I added an oil filter relocation (which uses the large FL1A) I had to put over a quart in put I pulled the exisiting filter which had oil in it. I am thinking it will hold 9 now. Next time I do an oil change I will post what it holds with this oil pan and relocation kit. Quote Link to comment Share on other sites More sharing options...
