ViperNC Posted February 19, 2013 Report Share Posted February 19, 2013 (edited) http://www.shelbysto...5mk-2300-ur.htm Been eyeballing these brakes for front and rear on my 09 car and was cleaning my wheels yesterday when I noticed the clearance between the rear stock caliper and the wheel is REALLY close. I'm wondering if I'll have any issues with this upgrade? My rear wheels have a three inch polished aluminum lip and wondering if I went too deep to upgrade the brakes. Any thoughts on this? Edited February 19, 2013 by ViperNC Quote Link to comment Share on other sites More sharing options...
ViperNC Posted March 1, 2013 Author Report Share Posted March 1, 2013 Update: Spoke with Wilwood and they are researching with Steve at True Forged to get full specs on the rear wheels and then take measurements. Won't have any clearance issues vertically with 20 inch wheels. The Wilwood rotor hat does set the rotor back further away from the wheel, but the question is if the caliper will clear the spokes of the wheel or not. Hope to have the answer soon. Quote Link to comment Share on other sites More sharing options...
super hiss Posted April 6, 2013 Report Share Posted April 6, 2013 I want to get cs40 wheels and I'm wondering the same thing for the same brand rear brakes as u are? Did they give any measurement or fitting info? Quote Link to comment Share on other sites More sharing options...
ViperNC Posted April 7, 2013 Author Report Share Posted April 7, 2013 Comment from Wilwood rep: The front caliper over-hang measurement of 1.17” is for the front 14” W6A kit. The 13”/14” FNSLR6 kits measure out to be .75”. So it looks like these kits would work fine in your wheels. The rear caliper over-hang is 0.01”…so this means, where the wheel mounts to the hat/rotor, the caliper sit’s pretty flush (minimal over-hang). So if your stock rear brakes fit your wheels, our kit will most definitely fit. Quote Link to comment Share on other sites More sharing options...
super hiss Posted April 7, 2013 Report Share Posted April 7, 2013 Whew, thank you... I really want both rims and brakes Quote Link to comment Share on other sites More sharing options...
super hiss Posted April 7, 2013 Report Share Posted April 7, 2013 Comment from Wilwood rep: The front caliper over-hang measurement of 1.17” is for the front 14” W6A kit. The 13”/14” FNSLR6 kits measure out to be .75”. So it looks like these kits would work fine in your wheels. The rear caliper over-hang is 0.01”…so this means, where the wheel mounts to the hat/rotor, the caliper sit’s pretty flush (minimal over-hang). So if your stock rear brakes fit your wheels, our kit will most definitely fit. Wait, those wildwood rear brakes fit got stock 07 gt500 wheels too right? Quote Link to comment Share on other sites More sharing options...
ViperNC Posted April 8, 2013 Author Report Share Posted April 8, 2013 Their fitment guide is from 2005 - 2013. Quote Link to comment Share on other sites More sharing options...
super hiss Posted April 23, 2013 Report Share Posted April 23, 2013 Oh, I forgot to ask. How's big of a difference was the swap? Quote Link to comment Share on other sites More sharing options...
ViperNC Posted April 23, 2013 Author Report Share Posted April 23, 2013 I have not pulled the trigger yet. Waiting to see if SPP will ever have a sale on these before ordering directly from Wilwood. Quote Link to comment Share on other sites More sharing options...
super hiss Posted April 23, 2013 Report Share Posted April 23, 2013 I saw in another post, I believe it was you, discussion about rear tires. You have 20" rims and a lowered shelby? Quote Link to comment Share on other sites More sharing options...
super hiss Posted May 14, 2013 Report Share Posted May 14, 2013 Shelby store is having a ridiculous steal sale on brakes!!!!!!! Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted May 23, 2013 Report Share Posted May 23, 2013 Hey guys, I pulled the trigger on both Wilwood fronts and rears. The fronts clear the SVTPP wheel better than the stock. The rears take a little extra install procedures. The rear axle shafts must be removed to assemble the parking brake component. In addition, I need to shave the rear sway bar ends just a bit to add more clearance from the inside rear rotors. This is being done tomorrow. Other than that, the brakes look great and you do notice the additional stopping power. Brake dust I'd nearly eliminated. I have pics if needed. Quote Link to comment Share on other sites More sharing options...
jfried Posted May 23, 2013 Report Share Posted May 23, 2013 Hey guys, I pulled the trigger on both Wilwood fronts and rears. The fronts clear the SVTPP wheel better than the stock. The rears take a little extra install procedures. The rear axle shafts must be removed to assemble the parking brake component. In addition, I need to shave the rear sway bar ends just a bit to add more clearance from the inside rear rotors. This is being done tomorrow. Other than that, the brakes look great and you do notice the additional stopping power. Brake dust I'd nearly eliminated. I have pics if needed. Can you post the pics? Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted May 23, 2013 Report Share Posted May 23, 2013 Front wheels, rear wheel, entire car Quote Link to comment Share on other sites More sharing options...
ViperNC Posted September 27, 2013 Author Report Share Posted September 27, 2013 (edited) The Wilwood's are on the car.... finally. Was a little surprised we had to pull the axles to install the rear parking brake assembly and had I known that I would have also gone forward with the low profile diff cover. Oh well. Another project for another time. 2nd item to note is the stock front brake backing plates don't fit with this setup. The plate itself comes in contact with the Wilwood rotor so you have to go with the Shelby brake duct kit. Lastly, I had concerns about the rear brakes fitting in the deep dish wheels and fortunately there is plenty of clearance. Unfortunately, the rotor hat on the Wilwood kit is about 3/8 inch less thickness than the stock hat which became an issue when we attempted to put the center caps back in the wheels and they made contact with the axle. So we are going to order a couple of aluminum wheel spacers to solve the issue. We did not have to cut the rear sway bar in this case as there was also plenty of clearance. Other than that, the car looks bad ass with the new setup. Will try to post up some photos soon. Edited September 27, 2013 by ViperNC Quote Link to comment Share on other sites More sharing options...
NordicShelby Posted September 27, 2013 Report Share Posted September 27, 2013 Hey guys, I pulled the trigger on both Wilwood fronts and rears. The fronts clear the SVTPP wheel better than the stock. The rears take a little extra install procedures. The rear axle shafts must be removed to assemble the parking brake component. In addition, I need to shave the rear sway bar ends just a bit to add more clearance from the inside rear rotors. This is being done tomorrow. Other than that, the brakes look great and you do notice the additional stopping power. Brake dust I'd nearly eliminated. I have pics if needed. Just curious to what the fronts and rear cost you? Did you get them on sale? Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted September 27, 2013 Report Share Posted September 27, 2013 Hello Nordic, I bought the front and rears in March 2013 and received 10% off (saved 416.24). Total $ out the door including shipping was $3979.91. I re-checked the price on Shelby Performance Parts website this morning and non discounted pricing was the same. Quote Link to comment Share on other sites More sharing options...
NordicShelby Posted September 27, 2013 Report Share Posted September 27, 2013 Hello Nordic, I bought the front and rears in March 2013 and received 10% off (saved 416.24). Total $ out the door including shipping was $3979.91. I re-checked the price on Shelby Performance Parts website this morning and non discounted pricing was the same. Thanks for the details. I want a set of Wilwoods really bad. Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted September 28, 2013 Report Share Posted September 28, 2013 Thanks for the details. I want a set of Wilwoods really bad. You will not be disappointed. Quote Link to comment Share on other sites More sharing options...
super hiss Posted September 28, 2013 Report Share Posted September 28, 2013 decided to just upgrade the front rotars and wilwood the rear... need to save 4 my engine Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted October 2, 2013 Report Share Posted October 2, 2013 Super hiss, Assuming your running the Brembo fronts, that set up will give you 4 piston back and front. I think the clamping force ratio is 70/30 predominately on the front. When you get them on, I would curious on if you notice any difference at all. I know when I changed the front, there was a noticeable difference. Quote Link to comment Share on other sites More sharing options...
super hiss Posted October 2, 2013 Report Share Posted October 2, 2013 bro brembos are 6 and the rears 1. the drilled / slotted rotors are whats a big increase. im sure ill be more than fine Quote Link to comment Share on other sites More sharing options...
super hiss Posted October 2, 2013 Report Share Posted October 2, 2013 well i guess that was only the 13+ shelbys not the prior... my bad Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted October 4, 2013 Report Share Posted October 4, 2013 bro brembos are 6 and the rears 1. the drilled / slotted rotors are whats a big increase. im sure ill be more than fine I always thought the factory Brembos were 4 pistons and rears were 1 pistion. My bad! Quote Link to comment Share on other sites More sharing options...
Geoffrey McCash 50962 Posted October 4, 2013 Report Share Posted October 4, 2013 well i guess that was only the 13+ shelbys not the prior... my bad Gotcha...The 13's had 6 piston. Did not know that. Quote Link to comment Share on other sites More sharing options...
super hiss Posted October 4, 2013 Report Share Posted October 4, 2013 dude, im getting soo pissed off fixing this half ass shit ford does. i might as well bought a beater and saved up for a 2013. thanks for the though ohio, i guess van thought i had a 2013 since he has so many clients. you should hear the guff he gives me for having kooks headers Quote Link to comment Share on other sites More sharing options...
05mustangman Posted October 4, 2013 Report Share Posted October 4, 2013 Curious to hear what the issue with kooks headers is. I've thought kooks is one of the best header companies. I love them on my car and they sound great. Besides stainless works and american racing, I don't believe they are that much better than kooks. I'm sure you will definitely love the brakes upgrades. After I did the Baer extremes, it was like a whole new car braking wise. Quote Link to comment Share on other sites More sharing options...
super hiss Posted October 6, 2013 Report Share Posted October 6, 2013 I just put $ on 2014 brembo 6 piston calipers, rotors and brakes lines. Do these fit s197 Shelby's?? Quote Link to comment Share on other sites More sharing options...
