Shelby Gauge Pod lights
Hey Board,
Has anyone changed their lights for the gauge pod to led colored lights? The different colors in the lights drives me nuts? Please let me know where I can find the lights and maybe help with some install instructions?
Thanks
TNTChris
Chris-
LED replacement bulbs can be found on the Autometer web site. They only sell the basic four colors red, green, yellow and blue. I purchased mine on Ebay at a much cheaper price. The bulbs are are easy to swap out. They are held in with a twist lock style socket. Use caution the sockets are weak and it's easy to break off a tab. If you search for bulbs using the sockets 161, 193, 194 & 168 wedge style. They might make more colors now then when I bought mine. I also was not a fan of the bulbs with the colored condoms on them. Good luck and I hope this helps. -Kevin
I originally tried the rubber "booties" on the factory bulbs, and Blue looked like Weak Aqua.
The LEDs are more $, but worth the difference.
Jer
I purchasrd from Jegs, they had the autometer Blue LED lights. They looked great with the blue all around
Can you share the link to the exact bulb you purchased? I want to make sure I get it right before ordering. Thanks.
Jim
Jer,
What color led's did you go with? Does the color match any of the My Color options? I tried the booties, but found the blue too dark, red too pink and the green just not a good match for the existing gauges.
I used blue. I have the MyColor set to pure blue, and it matches exactly.
Now if I could only get the green stuff in the dash to be blue.... LOL
Jer
I just ordered some blue bulbs from Summit. My question is do you actually twist the bulb to remove and install or just pull. The last thing I want to do is break something.
Edited by slygray1
I ordered these from Summit Racing this evening;
Auto Meter 3296 - Auto Meter Replacement Light Bulbs
http://www.summitrac.../parts/atm-3296
I will try to get some pics after they are installed!
TNTChris
Chris,
Are you certain this is the right part number? Check out the Autometer site directly. P/N 3296 mentions that this is a replacement bulb for some tachometers. P/N 3286 mentions that it replaces bulb style 161, 193, 194 and 168 and from the picture, looks like it has the same base as the exising bulb.
I copied this from the Autometer site. It looks like the 3296 bulbs are correct. The Shelby guages are 2 5/8"." These replacement bulb and socket assemblies and individual replacement bulbs from Auto Meter are designed for 1 1/2 in. mini, 2 1/16 in., and 2 5/8 in. gauges. They can also be used in some speedometers and tachometers".
Edited by slygray1
Some one help! I hope I ordered the right ones. :censored:
Jer, which ones did you order?
I bought them at SoCal Speed Shop here in town. They were in Auto Meter packaging. I forget the part #...
Jer
FYI for you guys getting the LEDs. They are polarity sensitive. ( only work one way ). If you install them and they don't work, flip 180 degrees and reinstall. I said many cuss words when changing mine for this reason. Also be careful with the wire splices. If yours is like mine, not a lot of excess wire under there and connections are sketchy at best.
